POV-Ray : Newsgroups : povray.general : A little trig help Server Time
3 Mar 2026 09:02:18 EST (-0500)
  A little trig help (Message 1 to 3 of 3)
Subject: A little trig help
Date: 26 Apr 2003 00:37:57
Message: <3eaa0d25$1@news.povray.org>
Ok .. I want to distribute 'things' equaly spaced around a streched disk.
I can do it on the plain disk easily enough:
            #local R = 1.75;
            #local V =.4;
            #local Count = 0;
            #local Max = 4;
            #while (Count < Max)
                #local Theta = Count * (360/Max);
                #local X = -R * cos(radians(Theta));
                #local Z = -R * sin(radians(Theta));
                #local Count = Count + 1;
                sphere{<0,0,0>.15 translate <X,V,Z>}
but I really want an oval? .. elipse? .. created by stretching the disk:
cylinder {<0,0,0><0,.5,0> 2 scale <1.5,1,1>}
I can place the 'decorations' equally spaced by degrees on a plain disk, but
what I want is to place them equally spaced by distance on a stretched disk.
Any suggestions appreciated
Subject: Re: A little trig help
Date: 26 Apr 2003 01:30:05
Message: <web.3eaa18733bdd876d34dff4bb0@news.povray.org>
>            #local R = 1.75;
>            #local V =.4;
>            #local Count = 0;
>            #local Max = 4;
>            #end
I know this code looks bizarre, but it works pretty good.  Try this inside
your loop:
                #local Theta = radians(Count * (360/Max));
                #local Theta = Theta + 0.1*sin(2*Theta);
                #local X = -1.5*R * cos(Theta);
                #local Z = -R * sin(Theta);
                sphere{<0,0,0>.15 translate <X,V,Z> pigment {color rgb 1}}
Now, if you want an explanation, I can't offer a very good one, but I'll
try.
Basically, you have to compensate for the fact that near Theta=0 and
Theta=pi, the points are too close together.
Near Theta=0, adding 0.1*sin(2*Theta) is pretty close to adding 0.2*Theta.
This means that near Theta=0, Theta is really 1.2*Theta, so the points will
be spread out.
Near Theta=pi/2, adding 0.1*sin(2*Theta) is really close to subtracting
0.2*(Theta-pi/2).  So, near Theta=pi/2, Theta is really 0.8*Theta + some
constant.
The effect is, Theta increases at a rate of between 0.8 and 1.2, instead of
at a constant rate of 1.  1.2/0.8 is 1.5, which is how skewed your ellipse
is.  So the points should be equally spaced near Theta =0,pi/2, pi, and
3/2*pi.  In between, there will be some variance, but it shouldn't be too
bad.
Date: 26 Apr 2003 04:06:17
Message: <3eaa3df9@news.povray.org>
Thanks
Alan
"Retsam" <nomail@nomail> wrote in message
news:web.3eaa18733bdd876d34dff4bb0@news.povray.org...
> >            #local R = 1.75;
> >            #local V =.4;
> >            #local Count = 0;
> >            #local Max = 4;
> >            #end
but
disk.
> your loop:
> try.
will
> be spread out.
> constant.
of
> bad.
