POV-Ray : Newsgroups : povray.general : POV tips/tricks Server Time
13 Jun 2026 01:49:14 EDT (-0400)
  POV tips/tricks (Message 1 to 6 of 6)
Subject: POV tips/tricks
Date: 13 Apr 2003 08:37:49
Message: <3e995a1d$1@news.povray.org>
Things I have learned to make POV-life easier:
For area light(s) and media, have media interaction off and no
shadow, and a point light at the same location with media
interaction on and no shadow.
For media-filled containers, give the object no shadow, and make
a duplicate object with a simple texture to cast the shadow with
no image and no reflection.
For objects with IOR that are only there for photon effects, use
no image on the refractive object.
For a light whose interaction with media is only in a small area
of the scene, make a media object surrounding the relevant space
with absorbtion a negative amount of the scattering; this will
remove the scattering of ambient light and only scatter the desired
light source.
For objects with transparent textures maps, if the alpha channels
of the textures are showing as opaque, make the object hollow.
Additions welcome!
Tim Cook
Version: 3.12
Subject: Re: POV tips/tricks
Date: 13 Apr 2003 08:39:15
Message: <3e995a73$1@news.povray.org>
Er sorry, have the area light with media interaction off, point
light with no shadow.  :P
Tim Cook
Version: 3.12
Date: 13 Apr 2003 12:46:49
Message: <3e999479$1@news.povray.org>
Thank you for sharing these Tim! :-)
Date: 13 Apr 2003 13:23:28
Message: <3e999d10@news.povray.org>
I haven't used media much, I think your tricks will be very useful when
venturing into that area.
Some things I've learned:
http://hertel.no/peter/povray.asp?pov=1&ray=2
-Peter
Date: 13 Apr 2003 17:47:31
Message: <3e99daf3@news.povray.org>
> shadow
  An area light with no shadow is like no area light at all... :)
Date: 13 Apr 2003 18:27:39
Message: <3e99e45b$1@news.povray.org>
A light with no shadow AND no media interaction is like no light
at all even more ;)
(area lights interact with media pretty damn slowly, but I'm gonna
be giving that a whirl in a render or two...)
Tim Cook
Version: 3.12
