POV-Ray : Newsgroups : povray.general : Transparency ?? Server Time
18 Sep 2025 18:34:04 EDT (-0400)
  Transparency ?? (Message 1 to 5 of 5)
Subject: Transparency ??
Date: 11 Apr 2003 15:27:23
Message: <3e97171b@news.povray.org>
Hello,
   I am experimenting with a way to simulate the motion blur of a spinning
rotor blade (like that of a helicopter).  I have had promising results by
using a simple disc object with a Radial color map texture.  The color map
is such that a portion of the map slowly ramps from complete transparency to
opacity, and then falls sharply back to complete transparency.  Increasing
Frequency to 4 makes the disc look like 4 individual blades spinning around
a center axis with the transparency emulating a trailing-edge motion blur.
My question is:
  Is there a way combine the transparency map with a cylindrical color map
to give the appearance of bands or stripes painted onto the 'spinning
blades'?
TIA!
Robert
Subject: Re: Transparency ??
Date: 11 Apr 2003 16:54:43
Message: <3e972b93$1@news.povray.org>
check the documentation for that.
you can use the wood pigment in a color map and then apply that into a
pigment map with your rotorblades.
"Robert C" <cre### [at] grunetnospam> schreef in bericht
news:3e97171b@news.povray.org...
> Hello,
to
around
> My question is:
> blades'?
> TIA!
> Robert
Date: 11 Apr 2003 17:29:26
Message: <3e9733b6@news.povray.org>
Gimme pic on povray.binaries.images if you feel like it..... :)
Date: 14 Apr 2003 14:21:41
Message: <3e9afc35$1@news.povray.org>
Yes, I could use a wood color map to apply to the Disc object, but then I
lose the radial transparency; the disc winds up looking looking like a
target or bullseye instead of 4 blades...
There's a sample at http://www.crewsr.net/images/sample.jpg
I have read the documentation, (but thanks for reminding me) and if
combining different types of color maps is covered somewhere (not layered
textures), please let me know what chapter.section it is in...
"Lenx" <len### [at] pandorabe> wrote in message
news:<3e972b93$1@news.povray.org>...
> > Hello,
map
transparency
> to
Increasing
> around
blur.
> > My question is:
> > blades'?
> > TIA!
> > Robert
"Lenx" <len### [at] pandorabe> wrote in message news:3e972b93$1@news.povray.org...
> > Hello,
spinning
by
map
transparency
> to
Increasing
> around
blur.
> > My question is:
map
> > blades'?
> > TIA!
> > Robert
Date: 15 Apr 2003 22:10:42
Message: <3e9cbba2$1@news.povray.org>
   Hi Robert,
   what you need is
      6.7.1.4  Pigment Map
      6.7.5.1 Texture Map
   The following little but complete scene shows how a texture map can
   be utilized to put stripes onto helicopter blades. The appearance
   near the center isn't realistic (as seen at the auxiliary rotor),
   but improved by composing the main rotor of an 'hollow' outer rotor,
   an inner rotor and an axle.
      Sputnik
//----- START OF ROTOR ----------------------------------------------
// texture for the gaps between blades
#declare ClearTex = texture { pigment { color rgbt <0, 0, 0, 1> } }
// texture for blades
#declare BladeTex = texture {
  pigment { onion
    frequency 3
    color_map {
      [ .3 rgbt <1, 0, 0, .2> ]
      [ .3 rgbt <1, 1, 1, .2> ]
  finish { }
//texture for 'inner rotor'
#declare DarkTex = texture { pigment { color rgbt <.3, .3, .3, .2> } }
// rotor macro
#macro Rotor (Diameter, Hole, Blades, Width, Blur, Tex)
  disc { 0, y, Diameter, Hole
    texture { radial
      frequency Blades
      triangle_wave
      texture_map {
        [ Width      Tex      ]
        [ Blur+Width ClearTex ]
  #end//macro Rotor
// rotor of helicopter
Rotor (3  , 0.5, 6, .5, .2, BladeTex)
Rotor (0.5, 0  , 6, .1, .2, DarkTex)
cylinder { 0.1*y, -0.3*y, 0.1 texture { DarkTex } }
// 'helicopter'
union {
  sphere { -y, 0.8 }
  cone { <0, -0.7, 0>, 0.5, <4, -0.7, 0>, 0 }
  texture { pigment { color rgb <1, .8, 0> } }
// auxiliary rotor
object { Rotor (1, 0, 4, .6, .2, BladeTex)
  rotate 90*x
  translate <4, -0.7, 0.2>
// ground plane, light, camera
plane { y, -3 texture { pigment { checker } } }
light_source { <1, 1, -1>*100, 1}
#camera { location  <-6, 10, -15> look_at -y angle 25 }
//----- END OF ROTOR ------------------------------------------------
