POV-Ray : Newsgroups : povray.general : Tips for povray being able to read freeware fonts Server Time
11 Jan 2026 11:54:34 EST (-0500)
  Tips for povray being able to read freeware fonts (Message 1 to 10 of 11)
Subject: Tips for povray being able to read freeware fonts
Date: 10 Apr 2003 22:52:52
Message: <3e962e04$1@news.povray.org>
I just downloaded four freeware fonts (.ttf) off the internet and was not
able to get povray to use any of them as a text object, whereas the code has
worked fine for other fonts, some freeware, definitely also timrom.ttf.
Any tips?
Subject: Re: Tips for povray being able to read freeware fonts
Date: 11 Apr 2003 02:17:49
Message: <dcnc9vkfncav6dmsak4au9241olkc2q979@4ax.com>
On Thu, 10 Apr 2003 22:52:53 -0700, "Greg M. Johnson" <gregj;-)565### [at] aolcom>
What you mean in "was not able"?
Error? Not expected appearance of rendering? Crash?
ABX
Date: 11 Apr 2003 09:44:57
Message: <3e96c6d9$1@news.povray.org>
Povray treats the object as if it were a rectangle when used in an object
pattern, which I believe is also what it will do if one types in a ficitious
FAKE.TTF filename.  It's the kind of rectangle you get when you look at the
font viewer for characters not supported.  I suppose I can get some bitmap
and code examples together much later.
"ABX" <abx### [at] abxartpl> wrote in message
news:dcnc9vkfncav6dmsak4au9241olkc2q979@4ax.com...
not
has
> ABX
Date: 11 Apr 2003 09:58:47
Message: <dphd9v8ne94putd910p74qdhpdlaq37b1q@4ax.com>
On Fri, 11 Apr 2003 09:44:21 -0400, "Greg M. Johnson" <gregj:-)565### [at] aolcom>
Mapping between keyboard and objects in TTD file are not trivial and can be
influenced in many places (keybord driver, language settings, character set,
application customization). The fact that in some application after pressing key
"letter" character "LETTER" appear on screen doesn't mean that in TTF file
"letter" is coded as "LETTER". Font viewer? Have you verified this font in
charmap.exe (iirc included in every standard Windows installation)?
Note, in charmap.exe can be selector for charset selection.
If this TTF will not work you can consider conversion from ttf vector format to
other vector format which can be later somehow imported into SDL as prism or
something.
ABX
Date: 11 Apr 2003 10:08:39
Message: <3e96cc67$1@news.povray.org>
Very helpful reply.  Will do the advised research "later"  ;-)
Date: 11 Apr 2003 10:13:56
Message: <c8jd9vkp43d1pcr0mplgsmeiukpuj7bq0n@4ax.com>
On Fri, 11 Apr 2003 10:08:04 -0400, "Greg M. Johnson" <gregj:-)565### [at] aolcom>
In lack of other tools you can consider extraction of specified character with
something like http://xml.apache.org/batik/ttf2svg.html to verify how this
character looks like.
ABX
Date: 11 Apr 2003 11:16:41
Message: <3e96dc59@news.povray.org>
I'm not sure if this is a silly suggestion or not, but I had this problem
once, and fixed it by including a charset directive in the global_settings
block
global_settings {
    charset utf8
Mark Hanford
www.hanfordonline.co.uk/povray
"Greg M. Johnson" <gregj:-)565### [at] aolcom> wrote in message
news:3e96c6d9$1@news.povray.org...
ficitious
the
> not
code
> has
timrom.ttf.
> > ABX
Date: 11 Apr 2003 22:25:27
Message: <3e977917$1@news.povray.org>
Ha! this was it.
Does this merit a doc addition??
"Mark Hanford" <ube### [at] blueyondercouk> wrote in message
news:3e96dc59@news.povray.org...
> block
> global_settings {
>     charset utf8
> Mark Hanford
object
> ficitious
> the
bitmap
was
> > not
> code
> > has
> timrom.ttf.
> > > ABX
Date: 12 Apr 2003 00:31:05
Message: <3E97968C.1718F30A@pacbell.net>
"Greg M. Johnson" wrote:
> Ha! this was it.
6.11.6  Charset
This allows you to specify the assumed character set of all text strings.
If you specify ascii only standard ASCII character codes in the range from
0 to 127 are valid. You can easily find a table of ASCII characters on the
internet. The option utf8 is a special Unicode text encoding and it allows
you to specify characters of nearly all languages in use today. We suggest
you use a text editor with the capability to export text to UTF8 to generate
input files. You can find more information, including tables with codes of
valid characters at http://www.unicode.org/ The last possible option is to
use a system specific character set. For details about the sys character set
option refer to the platform specific documentation.
Ken Tyler
Date: 12 Apr 2003 03:40:14
Message: <3e97c2de@news.povray.org>
In article <3e977917$1@news.povray.org> , "Greg M. Johnson"
<gregj;-)565### [at] aolcom> wrote:
> Ha! this was it.
No, as *usual* it would help you to RTFM.
    Thorsten
