POV-Ray : Newsgroups : povray.general : How to calculate the focal length? Server Time
3 Mar 2026 10:56:21 EST (-0500)
  How to calculate the focal length? (Message 1 to 8 of 8)
Subject: How to calculate the focal length?
Date: 29 Mar 2003 08:47:45
Message: <3e85a401@news.povray.org>
Hi!
POV-Ray uses the horizontal angle to determine the clipping. Does somebody
know how to calculate the focal length when only the horizontal angle is
given?
Andreas
http://www.render-zone.com
Subject: Re: How to calculate the focal length?
Date: 29 Mar 2003 09:05:19
Message: <3E85A858.67B58C91@gmx.de>
Andreas Kreisig wrote:
> Hi!
> given?
The relation between camera angle and focal length obviously depends on
the film/sensor size of the camera.
See for example:
http://www.colloquial.com/photo/formats.html
http://www.mat.uc.pt/~rps/photos/angles.html
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 29 Mar 2003 11:38:31
Message: <MPG.18efea74a47cc773989686@news.povray.org>
Andreas Kreisig wrote:..
> Hi!
> given?
> Regards,
> Andreas
I suppose that what you mean by "focal length" is the direction vector
(the distance between the focal point and the screen). The relation
between the horizontal angle and the focal length (direction) can be
found in the PovRay Help section 6.4.1.
Date: 29 Mar 2003 12:05:06
Message: <3e85d242@news.povray.org>
>> Hi!
>> somebody know how to calculate the focal length when only the horizontal
>> angle is given?
>> Regards,
>> Andreas
Hm, I meant the focal length of a virtual lens. This is not the same as the
distance between the focal point and the screen.
Andreas
Date: 29 Mar 2003 12:13:33
Message: <3e85d43c@news.povray.org>
>> Hi!
>> angle is given?
Yes, but my problem is that POV-Ray has no film or sensor size. The
background: I want to use the same camera settings in Blender than in POV.
POV-Ray uses the  (horizontal) 'angle' directive, Blender uses a focal
length similar to a real camera. I know that the angel of the camera has 25
degrees so I need the corresponding focal length.
Impossible?
Andreas
Date: 29 Mar 2003 12:24:16
Message: <3E85D6FA.1F6DBC09@gmx.de>
Why don't you read what i wrote.  The viewing angle of a (photographic)
camera with a certain focal length depends on what film format or sensor
it uses.  I don't know how Blender calculates a camera angle from a given
focal length but it has to assume a certain film format for that.
Date: 29 Mar 2003 13:21:30
Message: <3e85e42a@news.povray.org>
3E85D6FA.1F6DBC09@gmx.de...
> Christoph
I don't know more about blender but usually it is spoken of a 35mm  (36x24mm
image) film in that discussions.
so  as angle  means horizontal angle :
Angle of View = 2 * ArcTan(Size/ (2 * Focal Length * (1 + Magnification)))
assuming the lense is normal (not a macro one), Magnification can be
considered as 0.
 so
Angle of View = 2 * ArcTan(Size/ (2.Focal Length ))
and
Focal Length=(Size/2)*cotan(Angle/2)
But my maths are far away in the mists of ages so I can be wrong
Marc
Date: 29 Mar 2003 13:54:10
Message: <3E85EC0D.101EA7AD@gmx.de>
That's exactly what the first of the links i posted says too.  But there
is no reason why it has to be a 35mm film the calculations are based on.
