POV-Ray : Newsgroups : povray.general : "reference objects" Server Time
19 Sep 2025 04:18:32 EDT (-0400)
  "reference objects" (Message 1 to 7 of 7)
Subject: "reference objects"
Date: 1 Feb 2003 09:14:40
Message: <3e3bd650@news.povray.org>
I've been working with Moray for a couple years, and just recently started
learning to manipulate scenes in PovRay. One thing Moray has that I like is
the ability to create "reference objects", so that if you transform the
first object, all of the reference objects will automatically be transformed
in the same way. This is a great time saver. Does PovRay have a way of doing
the same thing?
Steve Shelby
Subject: Re: "reference objects"
Date: 1 Feb 2003 09:19:33
Message: <3e3bd775@news.povray.org>
Among other things, Steve Shelby wrote:
> Hi,
> is the ability to create "reference objects", so that if you transform the
> transformed in the same way. This is a great time saver. Does PovRay have
> a way of doing the same thing?
Well... you can #declare a transform and then reuse it as many times as you
wish.
Linux User #289967 (counter.li.org)
PGP Pub Key ID: 0x01A95F99 (pgp.escomplinux.org)
Date: 1 Feb 2003 10:51:41
Message: <3e3bed0d$1@news.povray.org>
Or you can declare an object and then use it numerous times... transform the
declared object and you get what you want.
D.
"Jellby" <jel### [at] M-yahoocom> wrote in message
news:3e3bd775@news.povray.org...
> > Hi,
started
the
have
you
> wish.
Date: 1 Feb 2003 11:58:34
Message: <3e3bfcba@news.povray.org>
Entre otras cosas, Dennis Miller tuvo a bien escribir:
> the declared object and you get what you want.
Yes, that's the way if all the objects are the same as the "reference" one.
But if they are of different kind (a sphere, a box, a cone, an mesh...),
declaring the transform is the best way, isn't it?
Date: 1 Feb 2003 12:35:33
Message: <3e3c0565@news.povray.org>
#declare referenceobject = sphere {
0,1
//stuff
object {
referenceobject
// stuff
object {
referenceobject
// stuff
//etc
 - Slime
[ http://www.slimeland.com/ ]
Date: 1 Feb 2003 17:15:26
Message: <3e3c46fe@news.povray.org>
I set up the scene the way Slime presented it below, and for ordinary
transformations, it works OK. My problem is with The "bend" transformation,
using Chris Colefax's bend.inc. It works OK with one object, but when
reference objects are added, it doesn't work at all. Maybe it's just a flaw
in the bend program?
Steve
----- Original Message -----
Newsgroups: povray.general
Sent: Saturday, February 01, 2003 12:34 PM
> 0,1
> //stuff
> object {
> referenceobject
> // stuff
> object {
> referenceobject
> // stuff
> //etc
>  - Slime
Date: 2 Feb 2003 21:54:35
Message: <3e3dd9eb@news.povray.org>
is
transformed
doing
> the same thing?
Interestingly enough, the answer might as well be 'No' -- depending upon
what you're looking for.
If you're looking just for coding time etc. saving, then look at previous
answers.
However, please be warned that all those '#local's and '#declares' do next
to nothing to save memory -- except for (IIRC) textures and meshes. All
other objects will one day explode right into your face if you instantiate
them... err, generously enough, thinking that you're only making
'reference's...
Even if you, say, #declare a huge CSG object and use it just once in 'object
{...}', you actually create *two* copies, one in the table, and one in the
scene.
Unfortunately, true mesh-like references are not always practical in
POV-Ray, due to rendering performance considerations.
