POV-Ray : Newsgroups : povray.general : tile-able hieghtfields Server Time
28 Dec 2025 14:24:05 EST (-0500)
  tile-able hieghtfields (Message 1 to 6 of 6)
Subject: tile-able hieghtfields
Date: 10 Jan 2003 17:59:40
Message: <3e1f505c@news.povray.org>
hi all,
here's a chunk of code for your consideration (m and cm are arbitrary units
of meters and centimeters)
//start
#local fn = function { pattern {granite} };
HF_Square (fn, no, no, <25,25>, yes, "square1.inc", <0,0,0>, <1,1,1>*m)
object{#include "square1.inc" scale <1,0.1,1> pigment{Green}}
HF_Cylinder(fn, no, no, <25,25>, yes, "cylinder1.inc", <0,0,0>, <0,0,1>*m,
5*cm,10*cm)
object{#include "cylinder1.inc" translate -5*cm*y pigment{Red}}
//end
How would I manipulate this such that the cylinder 'tiles' seamlessly with
the square. The basic end result I'm aiming for is a round_box with a real
normal as opposed to a normal normal... or is there an easier way?
thanks in advance
jim
Subject: Re: tile-able hieghtfields
Date: 10 Jan 2003 20:17:52
Message: <3e1f70c0@news.povray.org>
  I would say that the best and more versatile thing you could do is
to create a HF_RoundBox() macro which creates a mesh-heightfield with
the shape of a rounded box, with the same principle as the other HF_*
macros.
  Of course it's a rather laborious job to do, specially if you are
not very strong at math, but by looking at how the other HF_* macros
are made, it shouldn't be too difficult.
  I would say that the HF_Sphere() macro is closest to what you want to
do. Copying and modifying it might be the easiest way.
  Of course you can ask the author of the macros to kindly help you... :)
Date: 11 Jan 2003 04:45:01
Message: <Xns93006DA247AB0seed7@povray.org>
> macros.
 Just an idea, more general than the above: find the set parametric
equations for the "superquadratic ellipsoid" then plug in a forth function
for the displacement and build a mesh using 'param.inc' or the
'parametric' object.
Ingo
Date: 11 Jan 2003 06:17:03
Message: <Xns93007D3C6F52seed7@povray.org>
> function for the displacement and build a mesh using 'param.inc' or
> the 'parametric' object.
Couldn't resist, although I have to do other things, so here is the
basic stuff for the superellipsoid as a parametric without displacement.
Equation and information comes from:
http://diogenes.iwt.uni-bremen.de/vt/laser/papers/Wriedt-
superellipsoids-PartPartSystCharact-2002.pdf
param.inc can be found at: http://members.home.nl/seedseven/
#version 3.5;
#include "param.inc"
#include "math.inc"
global_settings {assumed_gamma 1.0}
camera {location <0,0,-3> look_at <0,0,0>}
light_source { <500,500,-500> rgb <1,0.9,0.8> }
light_source { <-100,100,-500> rgb <0.3,0.3,0.5> }
#declare A=1;   //controles the size
#declare B=1;
#declare C=1;
#declare N=0.4; //controles the shape
#declare E=3.3;
#declare F1=function(u,v){A*sgn(cos(u))*pow(abs(cos(u)),N)*sgn(cos(v))
*pow(abs(cos(v)),E)}
#declare F2=function(u,v){B*sgn(cos(u))*pow(abs(cos(u)),N)*sgn(sin(v))
*pow(abs(sin(v)),E)}
#declare F3=function(u,v){C*sgn(sin(u))*pow(abs(sin(u)),N)}
object {
  Parametric (
    F1, F2, F3,
    <-pi/2,-pi>, <pi/2,pi>,
    50, 50,""
  pigment {uv_mapping checker rgb 1 rgb <0,0,1> scale <0.2,0.1,1>}
  finish{specular 0.3}
  rotate <45,0,0>
Date: 12 Jan 2003 14:57:45
Message: <3e21c8b9@news.povray.org>
I think I should have worded my post a little better, I don't actually want
a round box, just something that would allow for CSG with rounded edges
using heightfields for the normal (if all that makes sense).
I haven't had chance to play with the code (and prob. won't be able to until
nest week) but I'm guessing the function needs to be "shifted" along such
that edges match.
Which raises another question  - how is the heightfield mapped onto a
cyinder and sphere in the HF_* macros? take the cylinder{0,y} where does the
mapping start?
thanks
jim
news:3e1f70c0@news.povray.org...
> macros.
x]
Warp -
Date: 13 Jan 2003 21:41:40
Message: <cjameshuff-C212AB.21413213012003@netplex.aussie.org>
In article <3e21c8b9@news.povray.org>,
> mapping start?
The macros take a function and pass it the actual vertices, and use
return value as the displacement amount. Things like spherical or
cylinderical mapping from this are pretty easy, there are functions
provided for it.
http://tag.povray.org/
