POV-Ray : Newsgroups : povray.general : er...huh? Server Time
12 Jan 2026 02:38:27 EST (-0500)
  er...huh? (Message 1 to 5 of 5)
Subject: er...huh?
Date: 15 Dec 2002 00:29:00
Message: <3dfc131c@news.povray.org>
ok, the following code:
#fopen window "c:\program files\moray for windows beta\mdl\balcony.csv" read
#read(window,tile_amount)
#declare tilearray=array[tile_amount][21]
#declare current_tile=0;
#while(defined(window))
   #read(window,tilenumber,rrr,ggg,bbb,points)
   #declare tilearray[current_tile][0]=tilenumber;
   #declare tilearray[current_tile][1]=rrr;
   #declare tilearray[current_tile][2]=ggg;
   #declare tilearray[current_tile][3]=bbb;
   #declare tilearray[current_tile][4]=points;
   #declare n=0;
   #while(n<points)
     #read(window,pointx,pointy)
     #declare tilearray[current_tile][5+n]=pointx;
     #declare tilearray[current_tile][6+n]=pointy;
     #declare n=n+2;
   #declare current_tile=current_tile+1;
#fclose window
with file "c:\program files\moray for windows beta\mdl\balcony.csv":
20
"Tile0001" 64 61 78 8 0 4 -29 0 0.8 -28.7 0.9 -28.1 0.8 -27 9 0.0 -28.0
0.0 -28.7 0.2 -29.0 0.4 -29.0
"Tile0002",55,52,66,5,1.7,-29.0,1.9,-28.7,1.2,-28.3,1.0,-29.0,1.7,-29.0
"Tile0003",70,68,84,6,2.5,-28.2,2.4,-27.9,1.9,-27.9,1.5,-28.2,2.2,-28.5,2.5,-28.2
"Tile0004",56,53,67,7,3.4,-29.0,3.6,-28.7,3.4,-28.3,2.8,-28.3,2.5,-28.6,2.8,-29.0,3.4,-29.0
"Tile0005",94,92,112,5,1.3,-28.1,1.6,-27.7,1.0,-27.5,1.0,-27.9,1.3,-28.1
"Tile0006",117,107,129,5,0.8,-27.7,0.8,-27.4,0.3,-27.2,0.0,-27.8,0.8,-27.7
"Tile0007",139,126,150,5,2.3,-27.6,2.3,-26.9,1.7,-27.1,1.5,-27.5,2.3,-27.6
"Tile0008",164,138,172,7,3.5,-27.0,3.2,-26.4,2.8,-26.3,2.5,-26.8,2.6,-27.3,3.2,-27.4,3.5,-27.0
"Tile0009",112,97,118,6,3.5,-27.9,3.3,-27.7,2.6,-27.6,2.6,-27.8,2.7,-27.9,3.5,-27.9
"Tile0010",140,122,146,6,4.1,-27.5,4.2,-27.1,3.9,-27.1,3.5,-27.6,3.7,-27.7,4.1,-27.5
"Tile0011",54,48,61,5,5.0,-29.0,4.8,-28.4,4.3,-28.7,4.4,-29.0,5.0,-29.0
"Tile0012",77,68,85,6,4.3,-28.5,4.5,-28.3,3.9,-27.8,3.6,-28.1,3.8,-28.5,4.3,-28.5
"Tile0013",102,86,109,5,4.9,-28.0,4.9,-27.7,4.2,-27.7,4.7,-28.2,4.9,-28.0
"Tile0014",77,64,83,6,6.0,-28.5,5.6,-28.0,5.1,-27.8,5.0,-28.2,5.2,-28.5,6.0,-28.5
"Tile0015",91,75,97,6,6.9,-28.4,7.1,-27.9,6.6,-27.5,5.8,-27.9,6.3,-28.5,6.9,-28.4
"Tile0016",73,62,85,6,7.6,-28.6,7.9,-28.2,7.3,-28.0,7.1,-28.5,7.3,-28.6,7.6,-28.6
"Tile0017",56,47,64,5,8.7,-29.0,8.3,-28.3,7.8,-28.8,7.9,-29.0,8.7,-29.0
"Tile0018",71,55,79,7,9.1,-28.7,9.6,-28.2,9.2,-27.9,8.7,-27.9,8.5,-28.1,8.9,-28.8,9.1,-28.7
"Tile0019",53,38,55,5,9.2,-29.0,10.0,-29.0,10.0,-28.4,9.8,-28.3,9.2,-29.0
"Tile0020",82,62,91,4,10.0,-28.2,10.0,-27.5,9.7,-27.8,10.0,-28.2
gives an error on line 3 of the CSV with a parse error "Expected 'float,
vector, or string literal', ,  found instead"...but the POV docs say the
data file needs be delimited by commas.  so why does POV like spaces as
delimiters but not commas?  How do I keep the comma-delimited file
format and still use it in POV?
Apart from that, how crappy is my first attempt at writing POV code?
Tim Cook
Version: 3.12
Subject: Re: er...huh?
Date: 15 Dec 2002 01:52:09
Message: <lJpOdDARZC$9Ewx9@econym.demon.co.uk>
It says that the data file needs to be delimited by commas. It doesn't
explain the details of the unpredictable results that you will get if
you try to use space and end-of-line as delimiters.
In this particular case, the input is
20
"Tile0001" 64 61 78 8 0 4 -29 0 0.8 -28.7 0.9 -28.1 0.8 -27 9 0.0 -28.0 0.0 -28.7 0.2
-29.0 0.4 -29.0
but the POV command  #read(window,tilenumber,rrr,ggg,bbb,points) returns
the following on the first pass:-
tilenumber = 64
rrr = 78
ggg = 0
bbb = -29
points = 0.8
This is not what anyone wants and you probably should not depend on POV
behaving in a predictable manner when supplied with data that is not
separated by commas.
If you want a series of characters that contain spaces and/or end-of-
line characters to be considered as a single field, then you should
enclose it in quotes and it will be read as a string (you can't get it
to read it as a number because numbers can't contain such characters).
Your code needs to look more like this:-
#fopen window "balcony.csv" read
   //#declare tilearray[current_tile][0]=tilenumber;  Note 1
   #declare n=0;
   #while(n<points)
     #declare n=n+1;                               // Note 2
#fclose window
Note 1: You can't do that with a string.
Note 2: You had n=n+2, which only reads half the points.
Your data should use only commas as delimiters, like this.
Note, in particular, that commas are needed at the ends of lines.
20,
"Tile0001",64,61,78,8,0,4,-29,0,0.8,-28.7,0.9,-28.1,0.8,-27,9,0.0,-28.0,
0.0,-28.7,0.2,
"Tile0002",55,52,66,5,1.7,-29.0,1.9,-28.7,1.2,-28.3,1.0,-29.0,1.7,-29.0,
"Tile0003",70,68,84,6,2.5,-28.2,2.4,-27.9,1.9,-27.9,1.5,-28.2,2.2,-28.5,2.5,-28.2,
"Tile0004",56,53,67,7,3.4,-29.0,3.6,-28.7,3.4,-28.3,2.8,-28.3,2.5,-28.6,2.8,-29.0,3.4,-29.0,
"Tile0005",94,92,112,5,1.3,-28.1,1.6,-27.7,1.0,-27.5,1.0,-27.9,1.3,-28.1,
"Tile0006",117,107,129,5,0.8,-27.7,0.8,-27.4,0.3,-27.2,0.0,-27.8,0.8,-27.7,
"Tile0007",139,126,150,5,2.3,-27.6,2.3,-26.9,1.7,-27.1,1.5,-27.5,2.3,-27.6,
"Tile0008",164,138,172,7,3.5,-27.0,3.2,-26.4,2.8,-26.3,2.5,-26.8,2.6,-27.3,3.2,-27.4,3.5,-27.0,
"Tile0009",112,97,118,6,3.5,-27.9,3.3,-27.7,2.6,-27.6,2.6,-27.8,2.7,-27.9,3.5,-27.9,
"Tile0010",140,122,146,6,4.1,-27.5,4.2,-27.1,3.9,-27.1,3.5,-27.6,3.7,-27.7,4.1,-27.5,
"Tile0011",54,48,61,5,5.0,-29.0,4.8,-28.4,4.3,-28.7,4.4,-29.0,5.0,-29.0,
"Tile0012",77,68,85,6,4.3,-28.5,4.5,-28.3,3.9,-27.8,3.6,-28.1,3.8,-28.5,4.3,-28.5,
"Tile0013",102,86,109,5,4.9,-28.0,4.9,-27.7,4.2,-27.7,4.7,-28.2,4.9,-28.0,
"Tile0014",77,64,83,6,6.0,-28.5,5.6,-28.0,5.1,-27.8,5.0,-28.2,5.2,-28.5,6.0,-28.5,
"Tile0015",91,75,97,6,6.9,-28.4,7.1,-27.9,6.6,-27.5,5.8,-27.9,6.3,-28.5,6.9,-28.4,
"Tile0016",73,62,85,6,7.6,-28.6,7.9,-28.2,7.3,-28.0,7.1,-28.5,7.3,-28.6,7.6,-28.6,
"Tile0017",56,47,64,5,8.7,-29.0,8.3,-28.3,7.8,-28.8,7.9,-29.0,8.7,-29.0,
"Tile0018",71,55,79,7,9.1,-28.7,9.6,-28.2,9.2,-27.9,8.7,-27.9,8.5,-28.1,8.9,-28.8,9.1,-28.7,
"Tile0019",53,38,55,5,9.2,-29.0,10.0,-29.0,10.0,-28.4,9.8,-28.3,9.2,-29.0,
Mike Williams
Gentleman of Leisure
Date: 15 Dec 2002 03:24:16
Message: <3dfc3c30@news.povray.org>
the problem was the lack of comma at end of line; see end note
k
note the pointx and pointy being 5+n and 6+n, meaning if i
only increase n by 1 i'd get duplicate numbers
hmm ok that was the primary cause of the problem
pushing onwards...
Tim Cook
Version: 3.12
Date: 15 Dec 2002 14:57:30
Message: <HcFWYEAg6H$9EwFo@econym.demon.co.uk>
OK, but if you use n+2 you need to say
   #while (n < points * 2)
Mike Williams
Date: 16 Dec 2002 06:12:23
Message: <3dfdb517$1@news.povray.org>
Yep.  Figured that out.  Was wondering why it kept giving array out of
bounds errors...:P
Tim Cook
Version: 3.12
