POV-Ray : Newsgroups : povray.general : Output file name Server Time
28 Dec 2025 17:47:45 EST (-0500)
  Output file name (Message 1 to 2 of 2)
Subject: Output file name
Date: 12 Nov 2002 18:45:42
Message: <3dd192a6@news.povray.org>
Is there any way to tell Povray not to add a suffix to the output file
name I give it? E.g. if I use "+FN +Ofoo", I want the output file to be
called "foo", not "foo.png". (OK, that's a silly example, but there are
cases where I need to use a nonstandard extension for the benefit of
other programs that will be reading the file.)
Ross Smith ...................... Pharos Systems, Auckland, New Zealand
"I write science fiction and fantasy for a living. The science fiction
is labelled 'Technical proposal', and the fantasy is labelled 'Budget
estimate'." -- Jordin Kare
Subject: Re: Output file name
Date: 12 Nov 2002 19:58:05
Message: <3dd1a39d$1@news.povray.org>
"Ross Smith" <ros### [at] pharosconz> wrote in message news:3dd192a6@news.povray.org...
: Is there any way to tell Povray not to add a suffix to the output file
: name I give it? E.g. if I use "+FN +Ofoo", I want the output file to be
: called "foo", not "foo.png". (OK, that's a silly example, but there are
: cases where I need to use a nonstandard extension for the benefit of
: other programs that will be reading the file.)
: Ross Smith ...................... Pharos Systems, Auckland, New Zealand
: "I write science fiction and fantasy for a living. The science fiction
: is labelled 'Technical proposal', and the fantasy is labelled 'Budget
: estimate'." -- Jordin Kare
I just tested the master INI with:
Output_File_Name=D:\Images\test.
And it made a file named "test" with no file extension. So try just
appending the period in +Ofoo.
=Bob=
