POV-Ray : Newsgroups : povray.general : Spherical blob components render faster Server Time
22 Apr 2026 06:44:23 EDT (-0400)
  Spherical blob components render faster (Message 1 to 10 of 15)
Subject: Spherical blob components render faster
Date: 2 Nov 2002 13:28:50
Message: <3dc41962$1@news.povray.org>
Remco made me aware of this astonishing  fact in p.b.a.  Here is a scene
file that makes it obvious.
A compact stack of 250 cylinders renders in 73 seconds.
A compact stack of 250 spheres renders in 6 seconds.
// Persistence of Vision Ray Tracer Scene Description File
// File: ?.pov
// Vers: 3.5
// Desc: Basic Scene Example
// Date: mm/dd/yy
// Auth: ?
#version 3.5;
global_settings {
  assumed_gamma 1.0
  location  <0.0, 0.5, -4.0>
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-30, 30, -30>
plane {
  y, -1
  pigment { color rgb <0.7,0.5,0.3> }
blob{threshold 0.4
#declare n=0;
#while(n<250)
        sphere {0,.4,1 scale <1,0.1,1> translate 0.005*y*n-0.5*y }
        //cylinder {0,y,.4,1 scale <1,0.1,1> translate 0.005*y*n-0.5*y }
#declare n=n+1;
      radial
      frequency 8
      color_map {
        [0.00 color rgb <1.0,0.4,0.2> ]
        [0.33 color rgb <0.2,0.4,1.0> ]
        [0.66 color rgb <0.4,1.0,0.2> ]
        [1.00 color rgb <1.0,0.4,0.2> ]
    finish{
      specular 0.6
Subject: Re: Spherical blob components render faster
Date: 2 Nov 2002 14:03:16
Message: <3dc42173@news.povray.org>
  I don't see what's so astonishing in this. One would expect that a more
complicated shape would render slower than a simpler one, and that's what
happened.
  Of course the difference in speed is a bit large, but still not
astonishing...
Date: 2 Nov 2002 15:21:57
Message: <3dc433e5@news.povray.org>
"Greg M. Johnson" <gregj:-)56590@ao:-)l.com> wrote in message
news:3dc41962$1@news.povray.org...
Why is this astonishing? What did you expect?
Not only are cylinders harder to solve for, using more complex math, but
bounding is much less effective. An unscaled sphere always fills the
majority of its bounding box, a cylinder can fill a very small percentage.
And I think the blob components are sphere bounded, which would make
cylinders even less efficient. Of course they are slower...
Date: 2 Nov 2002 16:01:32
Message: <3DC43D06.9B292E8@pacbell.net>
I think it would be astonishing to presume that the average user would
know the internal workings of POV-Ray enough to come to the same
conclusion :)
Ken Tyler
Date: 2 Nov 2002 16:24:46
Message: <3dc4429e@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3DC### [at] pacbellnet...
> conclusion :)
OK, point taken, but even without all that, it seems like it should be
expected that a more complex shape is going to be slower. Being "astonished"
at it seems very strange...am I missing some meaning and reading things too
literally?
Date: 2 Nov 2002 19:33:36
Message: <3DC46EBA.AC7C405A@pacbell.net>
> > conclusion :)
> literally?
From the average user vantage point I fail to see where a blob constructed
from cylinders is any more complex than a blob constructed from spheres.
After all, they are both simple basic shapes, are they not?
Ken Tyler
Date: 2 Nov 2002 20:09:05
Message: <3dc47731@news.povray.org>
de news: 3dc4429e@news.povray.org...
> > conclusion :)
"astonished"
too
> literally?
It's just that for the layman a cylinder is not a more complex shape than a
sphere. Even for a non-layman in fact... Both equations are very similar
after all. I don't dispute the fact that it's computationally more
expensive, but the difference in rendering time reported by Greg is really
big (x 10 !!!).
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 2 Nov 2002 22:34:57
Message: <3dc49961$1@news.povray.org>
news:3DC46EBA.AC7C405A@pacbell.net...
exactly.
Date: 2 Nov 2002 22:43:57
Message: <3dc49b7d@news.povray.org>
"Gilles Tran" <git### [at] wanadoofr> wrote in message
news:3dc47731@news.povray.org...
a
> sphere.
Hmm...maybe I'm just looking at it differently, but having two spherical
caps and a cylinderical section seems intuitively more complex than a
sphere.
> after all.
And for an isosurface function with axis-aligned cylinders, a cylinder
function is simpler...understandable confusion there. There are other
complications in the case of blob components which I don't expect "laymen"
to understand, but isosurfaces are more of an advanced user feature anyway.
> big (x 10 !!!).
That did catch me off guard, it seemed suspicious until I took bounding into
account, which I don't expect the average user to think of. The fact that
one is slower than the other just seems pretty expected to me, I'd be very
surprised if any two primitives were exactly the same as far as speed, and
without looking at the math I'd guess that the cylinder is the slower one.
An idea: use "hierarchy off" and compare the speeds then...it should
eliminate the bounding differences, leaving only the blob calculation
differences. If my guess is right, the sphere component blobs will slow down
more than the cylinder component ones, bringing them closer to equal.
Date: 3 Nov 2002 06:00:38
Message: <4c0asug9885shf979rnrq15pmtksuj117g@4ax.com>
On Sun, 3 Nov 2002 10:47:49 -0500, "Christopher James Huff"
>sphere.
It's not two caps and a cylinder, actually. It's just that the
distance function used computes the distance to a segment, 's all.
Peter Popov ICQ : 15002700
