POV-Ray : Newsgroups : povray.general : Calculating the View Factor? Server Time
25 Nov 2025 06:38:37 EST (-0500)
  Calculating the View Factor? (Message 1 to 5 of 5)
Subject: Calculating the View Factor?
Date: 24 Oct 2002 09:38:33
Message: <3db7f7d9$1@news.povray.org>
is it possible to calculate the view factor for all objects? I want to
calculate the "radiation-heat-transfer" from one object to another.
Thanks, Fabian
Subject: Re: Calculating the View Factor?
Date: 24 Oct 2002 11:06:28
Message: <3DB80C74.F5D91A94@gmx.de>
> Hi,
> Thanks, Fabian
This has nothing to do with POV-Ray and raytracing but the only
practicable way i know of calculating view factors for arbitrary
geometries is the FEM based approach and since shapes in POV-Ray are not
triangle based in general there isn't any easy way of doing this.
Date: 24 Oct 2002 11:14:27
Message: <3DB80E6F.6030009@free.fr>
Christoph Hormann wrote:
>>Hi,
>>Thanks, Fabian
What about using photons and counting ?
No... just a silly thought...
Date: 24 Oct 2002 11:24:37
Message: <3db810b5$1@news.povray.org>
> Hi,
> Thanks, Fabian
I guess you are talking about the *form* factor calculation for radiosity.
But even if this is true, I do not understand your question..
POV has already a method to calculate radiosity implemented.
-Ive
Date: 24 Oct 2002 16:41:56
Message: <3db85b14$1@news.povray.org>
> -Ive
To calculate the total heat-transfer I need the parts for conduction,
convection and radiation. The radiation heat from one area to a second
results in the product of the average view factor and the area. With the
view factor only the areas, which are seen by an object, were considered; so
objects(areas) in the shadow of one view point were neglected.
My idea is now to change the view-point to every (almost every) point of the
scene and calculate it with an area_light. The intensity of the calculated
area_light at every considered pixel should now respond to the "view
factors". Maybe, it is possibel to write the intensity for the areas to a
file? (How?)
Greetings Fabian
(Hopefully anybody understands my English)
