POV-Ray : Newsgroups : povray.general : Even distribution on a sphere Server Time
6 Oct 2024 07:20:42 EDT (-0400)
  Even distribution on a sphere (Message 1 to 10 of 24)
Subject: Even distribution on a sphere
Date: 15 Oct 2002 07:03:11
Message: <3dabf5ef$1@news.povray.org>
Okay, I'm trying to randomly distribute objects, using trace, on a sphere.
So, I do something like:
RotZ = 180*rand(R1)
RotY = 360*rand(R1)
Trans = transform(translate y*10 rotate z*RotZ rotate y*RotY)
TVec = vtransform(<0,0,0>, Trans)
Inter = trace(Ob, TVec, -TVec)
The trouble is that I end up with a bunching of objects at the poles for all the
obvious reasons, so the question is, how do I best avoid this? I assume it's
something like:
ZRotFac = 1 + pow(abs((ZRot/90)-1),2);
ZRot = ZRot * ZRotFac
But,
a) is this correct? (well, it's not, afaik - the range 1..2 is too limited imho)
b) if not, what is?
#macro A(V,B,C,R)#while(B-256)#if(V-128/B>=0)sphere{0,.5translate<C-4R-1,9>
pigment{rgb<1-C/8R/2C/8>}}#local V=V-128/B;#end#local B=B*2;#local C=C+1;#
end#end A(234,1,0,2)A(85,1,0,1)A(81,1,0,0)light_source{-5 1}//Tom Melly
Subject: Re: Even distribution on a sphere
Date: 15 Oct 2002 07:24:08
Message: <3dabfad8@news.povray.org>
I've come across the same problem some time ago,
so I implemented a macro which calculated an
electrostatic-repulsion algorithm. Some animations of
this macro can be found on my website.
If you want the code, I can see if I have to clean
the code a little or if I can send it to you right
away, just give me an email-adress.
Tim
Tim Nikias
Email: Tim### [at] gmxde
> RotZ = 180*rand(R1)
> RotY = 360*rand(R1)
all the
it's
> something like:
> But,
imho)
> b) if not, what is?
Date: 15 Oct 2002 07:26:35
Message: <rkunqu4ivtu7928rrf12ti4jo7jn8u86r6@4ax.com>
On Tue, 15 Oct 2002 12:03:11 +0100, "Tom Melly" <tom### [at] tomandlucouk> wrote:
> b) if not, what is?
My answer is not real answer but ... there is a macro in rand.inc include file
in standard distribution called VRand_On_Sphere.
ABX
Date: 15 Oct 2002 07:51:42
Message: <3dac014e@news.povray.org>
"Tim Nikias" <tim### [at] gmxde> wrote in message
news:3dabfad8@news.povray.org...
Probably overkill in this case ("electrostatic repulsion algorithm"? Yoiks!) -
I've got some close approximations working (well, good enough for gov. work).,
but many thanks for the offer.
Date: 15 Oct 2002 07:53:51
Message: <3dac01cf$1@news.povray.org>
"ABX" <abx### [at] abxartpl> wrote in message
news:rkunqu4ivtu7928rrf12ti4jo7jn8u86r6@4ax.com...
Ah, many thanks.....
Eep - I thought it might give me a clue, but I can't understand it at all. I
could rewrite some stuff to allow me to use it in this particular instance, but
that won't be as much fun as actually learning something....
Date: 15 Oct 2002 07:57:21
Message: <3dac02a1$1@news.povray.org>
I'm not sure if its overkill, depends on what
you're trying to achieve. Still, the macro is very
easy to handle and needs to be run only once,
the data is then saved and can be loaded with
my I/O-Macros (which are available on my website).
But it depends on the amount of objects you're trying
to spread, as always with algorithms pending on amount...
Tim
Tim Nikias
Yoiks!) -
work).,
Date: 15 Oct 2002 08:30:08
Message: <3dac0a50$2@news.povray.org>
news:3dac02a1$1@news.povray.org...
Branch coral (well, distributing the coral) - I've posted an image to
binaries.images
Date: 15 Oct 2002 09:31:24
Message: <3dac18ac@news.povray.org>
Maybe this one from Mike Andrews last year might make some sense. Sure is
confusing to me though.
news://povray.org/3B97457B.26C14AE4@reading.ac.uk
That randomly distributed point macro ABX brought up, VRand_On_Sphere() is
of course 'random', and looking at that now I don't know how to go about
derandomizing it. Trying to here and I get nonuniform distribution and
nothing better.
Date: 15 Oct 2002 09:55:08
Message: <3dac1e3c@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3dabf5ef$1@news.povray.org...
Hmm, this seems to work for a hemisphere (which is all I need - although I'm
going to try and figure out how to make it work with any specified max angle).
// okay where MZRot = 90
#local ZRot = pow(rand(Rand1),0.5) * MZRot;
#local YRot = rand(Rand1) * MYRot;
Date: 15 Oct 2002 10:20:52
Message: <3dac2444@news.povray.org>
news:3dac1e3c@news.povray.org...
and this (rather kludgy) approach seems to work for a specified MZRot:
    #local ZRot = pow(rand(Rand1),0.5) * 90;
    #local YRot = MYRot*rand(Rand1);
    #if(rand(Rand1)<0.5)
      #local ZRot = 180 - ZRot;
    #if(ZRot <= MZRot)
            .... position coral
            ..... increment counter
