POV-Ray : Newsgroups : povray.general : How to get the reflection data Server Time
23 May 2026 22:51:04 EDT (-0400)
  How to get the reflection data (Message 1 to 7 of 7)
Subject: How to get the reflection data
Date: 19 Sep 2002 19:12:41
Message: <3d8a59e9$1@news.povray.org>
Hi all,
  I am a new user of pov-ray. I want to know how to get the reflection data
which are used to form the scenes.
Thanks
Wu
Subject: Re: How to get the reflection data
Date: 19 Sep 2002 19:40:27
Message: <chrishuff-011ECD.19382719092002@netplex.aussie.org>
In article <3d8a59e9$1@news.povray.org>,
Well, my first thought is that you don't understand how POV does
reflections. When a ray hits a reflective surface, POV computes the
direction it would reflect off in from the intersection point and
normal, and the incoming ray direction and origin. It then starts
tracing another ray in the reflected direction, and uses the color
computed along that ray as the reflected color. There isn't any
"reflection data", just a lot of rays. It sounds like you might be
looking for environment map data, POV doesn't use environment maps, it
uses raytracing to compute true reflections instead.
You could hack in a bit of code that writes all reflected rays to a
file, I don't know if that would be of any use to you. The function to
modify would be Reflect() in lighting.cpp. Or you could do it at a lower
level and modify Trace() in render.cpp to output data for every ray
traced.
http://tag.povray.org/
Date: 20 Sep 2002 19:41:17
Message: <3d8bb21d@news.povray.org>
  Thank you for your reply. You message is very helpful for me. In your
letter, you mentioned some C++ files and functions. Would you please inform
me where I can find them.
Thanks
Wu
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
data
> traced.
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
Date: 20 Sep 2002 21:01:41
Message: <chrishuff-9D4B39.20594420092002@netplex.aussie.org>
In article <3d8bb21d@news.povray.org>, "Wu Yang" <wya### [at] cswrightedu>
You can download the POV-Ray source code on the POV-Ray web page at the
same place you download the executables.
Date: 25 Sep 2002 21:02:29
Message: <3d925ca5$1@news.povray.org>
   I tried to build povray.dsw, but I can not get PVENGINE.EXE in
WINDOWS\VC6\BIN directory. Do you know the reason?
Thanks
Wu
inform
Date: 30 Sep 2002 23:03:26
Message: <chrishuff-9A6608.23004130092002@netplex.aussie.org>
In article <3d925ca5$1@news.povray.org>,
Sorry, I don't have Windows and have never used Visual C++, so I'm not
much help there. Maybe try asking again in povray.programming.
Date: 3 Oct 2002 11:50:42
Message: <3d9c6752$1@news.povray.org>
Thank you for your reply. I have gone through it.
Wu
