POV-Ray : Newsgroups : povray.general : a couple of wierd things happened Server Time
4 Mar 2026 06:44:38 EST (-0500)
  a couple of wierd things happened (Message 1 to 6 of 6)
Subject: a couple of wierd things happened
Date: 2 Sep 2002 19:37:14
Message: <3d73f62a@news.povray.org>
Hi all,
While working on my IRTC entry I kept running into some weird behaviour, I
not seen in pov before - although I suspect it's more to do with my sloppy
coding than anything in pov.
1. When unioning or merging objects together like this:
    union{
        box{blah blah etc}
        sphere{blah...}
I got an error message saying something like "no } found in union box found
instead"
2. I had disappearing objects - objects which I know are on camera, but
aren't rendered. Checking their location with min_extent and max_extent
shows they are where I think they should be. Drawing a box using the
bounding box from the extent calcs doesn't draw a box but the object that
disappeared.
i.e. like this:
    #local table = blah, blah etc
    #local MIN = min_extent(table);
    #local MAX = max_extent(table);
    object(table)
doesn't trace the table, but adding this line
    box{MIN,MAX pigment{Red} }
draws the table but not the red box.
confused yet?
jim
Subject: Re: a couple of wierd things happened
Date: 2 Sep 2002 19:54:35
Message: <3D73FB0A.4C8D823D@pacbell.net>
James Taylor wrote:
> Hi all,
>     union{
>         box{blah blah etc}
>         sphere{blah...}
> instead"
Those kinds of error messages are always about syntax problems on your part.
Likely a missing closing brace somewhere. Did you accidentally use a parenthesis
somewhere maybe? Or not close a pigment, texture or finish statement?
Ken Tyler
Date: 3 Sep 2002 05:10:46
Message: <3d747c96@news.povray.org>
"James Taylor" <jim### [at] blueyondercouk> wrote in message
news:3d73f62a@news.povray.org...
> Hi all,
What sort of camera are you using? Objects can often disappear when using, iirc,
orthographic cams. It's not a bug, BTW, but you'd be better off getting an
explanation from someone more technically-minded than me.
Date: 3 Sep 2002 07:43:19
Message: <3d74a057$1@news.povray.org>
>     union{
>         box{blah blah etc}
>         sphere{blah...}
found
> instead"
Try using "Ctrl-]" (in Windows) to trace your bracket pairings.
-tgq
Date: 3 Sep 2002 15:04:29
Message: <3d7507bd@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3D73FB0A.4C8D823D@pacbell.net...
part.
parenthesis
yeah, first thing I checked - but commenting out the union and everything's
fine. THe only way round it I've found is to individually translate each
object that would have been in a union :(
jim
Date: 3 Sep 2002 15:04:30
Message: <3d7507be$1@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3d747c96@news.povray.org...
iirc,
just a regular perspective camera - i'll look into the probelm when I have
some time, the IRTC deadline was looming (didn't even start the final render
till 12.15am 1st sep) so it just got left as a quick fix.
jim
