POV-Ray : Newsgroups : povray.general : Image_map reuse? Server Time
25 Nov 2025 15:12:44 EST (-0500)
  Image_map reuse? (Message 1 to 3 of 3)
Subject: Image_map reuse?
Date: 24 Aug 2002 15:31:09
Message: <3d67defd$1@news.povray.org>
It seems ankward that I have to load an image_map twice into memory if I
want to use 2 kinds of map_types (spherical, cylindrical etc.) with the same
image... Is there are way around that? Maybe a function?
Hugo
Subject: Re: Image_map reuse?
Date: 25 Aug 2002 19:21:01
Message: <chrishuff-E4B17A.19210525082002@netplex.aussie.org>
In article <3d67defd$1@news.povray.org>, "Hugo" <hua### [at] post3teledk>
#declare basePig = pigment {image_map {...}}
#declare sphPig = pigment {basePig warp {spherical}}
#declare cylPig = pigment {basePig warp {cylindrical}}
#declare torPig = pigment {basePig warp {toroidal}}
I'm pretty certain POV copies image data by reference, similarly to how
meshes handle geometry data. Even if it doesn't, this will avoid reading
and decoding the file for every use and makes it easier to make
changes...you only need to change the image name in one place.
http://tag.povray.org/
Date: 26 Aug 2002 04:09:10
Message: <3d69e226$1@news.povray.org>
Thanks! Yes of course, a warp!  Although it's slower to render....
Thanks,
Hugo
