POV-Ray : Newsgroups : povray.general : Saving Photon maps Server Time
25 Nov 2025 15:11:18 EST (-0500)
  Saving Photon maps (Message 1 to 4 of 4)
Subject: Saving Photon maps
Date: 20 Aug 2002 20:23:20
Message: <3d62dd78@news.povray.org>
I know that if anything changes within a scene you need to save (rather than
load) a new photon map file.  Does the same thing hold true if you alter the
render size?  For example I render an image at 320x200 and save the photon
map.  Would I use the same map if I rendered the same scene at 1280x1024 or
will it need to be "reshot"?
Subject: Re: Saving Photon maps
Date: 20 Aug 2002 23:24:36
Message: <pan.2002.08.21.03.23.51.442217.210@gte.net>
On Tue, 20 Aug 2002 20:23:03 -0400, Patrick Dugan quoth:
> than load) a new photon map file.  Does the same thing hold true if you
> alter the render size?  For example I render an image at 320x200 and
> save the photon map.  Would I use the same map if I rendered the same
> scene at 1280x1024 or will it need to be "reshot"?
From a recent posting of mine in povray.advanced-users:
>Rafal 'Raf256' Maj wrote in message ...
>>Hi,
>>when data for photons and/or media can NOT be safle loaded ?
>>I ques that camera moving/rotation is alwys safe, and any other changes is
>>scene (objects or lights) is not safe - is this correct ?
>Moving the camera is always safe.  Moving lights that do not cast photons is
>always safe.  Moving objects that do not have photons shot at them, that do
>not recieve photons, and would not recieve photons in the new location is
>always safe.  Moving an object that recieves photons to a new location where
>it does not recieve photons is sometimes safe.  Moving an object to a
>location where it recieves photons, moving an object that has photons shot
>at it, or moving a light that casts photons is not safe.
>Changing the texture of an object that recieves photons is safe.  Changing
>the texture of an object that has photons shot at it produces results that
>are not realistic, but can be useful sometimes.
In general, changes to the scene geometry require photons to be re-shot.
Changing the camera parameters or changing the image resolution does not.
Mark
Date: 21 Aug 2002 13:16:04
Message: <3d63cad4@news.povray.org>
Thank you.
"Mark Wagner" <mar### [at] gtenet> wrote in message
news:pan### [at] gtenet...
> >>Hi,
is
is
do
where
shot
Changing
that
> Mark
Date: 21 Aug 2002 14:30:18
Message: <3d63dc3a$1@news.povray.org>
than
the
or
Usually no, but if you had very few photons in the 320 x 200 image - just
enough to make it look good - then when you increase the resolution you may
notice flaws. In that case you would have to increase count or decrease
spacing and reshoot them.
 - Slime
[ http://www.slimeland.com/ ]
