POV-Ray : Newsgroups : povray.general : Jitterand AA Server Time
12 Jan 2026 20:14:18 EST (-0500)
  Jitterand AA (Message 1 to 5 of 5)
Subject: Jitterand AA
Date: 17 Aug 2002 16:42:59
Message: <3d5eb553@news.povray.org>
I am tryingan animation, and have in my ini file these lines:
	quality=9
	antialias=on
	jitter=0
	sampling_method=1
	radiosity=off
	Continue_Trace=true
	Preview_Start_Size=1
yet looking at the outpout from povray (on linux) it states:
Antialiasing.........On  (Method 1, Threshold 0.300, Depth 3, Jitter 1.00)
How do I turn jitter off and have antialias on in povray 3.5?
Thanks
Subject: Re: Jitterand AA
Date: 17 Aug 2002 18:52:38
Message: <3d5ed3b6$1@news.povray.org>
did you try
# povray +J0.0 +A
Date: 17 Aug 2002 22:29:20
Message: <3d5f0680@news.povray.org>
On Sun, 18 Aug 2002 10:53:25 +1200, Jan Walzer wrote:
> did you try
> # povray +J0.0 +A
No, why do I need to specifiy the options on the command line as well as
  in the .ini file?
I have just tried it, and it works if i use the ini and just +J0.0 on the
cli, is this a just a bug or the way it should be?
Date: 17 Aug 2002 23:40:33
Message: <3d5f1731@news.povray.org>
  Put the +J0.0 in the ini file.
Date: 18 Aug 2002 03:41:45
Message: <3D5F501C.C5526ABB@pandora.be>
Rob Brown-Bayliss wrote:
> Hi,
>         quality=9
>         antialias=on
>         jitter=0
>         sampling_method=1
>         radiosity=off
>         Continue_Trace=true
> Thanks
I had the same problems and succeeded in putting
Jitter_Amount=0
in the ini file.
Herman Serras
Gent (Belgium)
http://cage.rug.ac.be/~hs/
