POV-Ray : Newsgroups : povray.general : command line DV .avi program... Server Time
10 Sep 2025 00:32:01 EDT (-0400)
  command line DV .avi program... (Message 1 to 9 of 9)
Subject: command line DV .avi program...
Date: 12 Aug 2002 11:59:05
Message: <3d57db49$3@news.povray.org>
Hi all,
Has anyone found a command line program that can take a seris of sequential
images and make an DV .avi file?  It must be fully automated and be able to
be run from a perl script.  There must be something out there....
Cheers,
Paul
Subject: Re: command line DV .avi program...
Date: 12 Aug 2002 19:12:23
Message: <3d5840d7@news.povray.org>
  What is a DV .avi file?
Date: 13 Aug 2002 02:21:36
Message: <3d58a570@news.povray.org>
In article <3d5840d7@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
My guess would be that it is an avi file containing the DV file data from a
DV camcorder (that is a digital one, just search the net if you don't know
them).
I have to admit that I don't even know if avi supports it, but I do know
that QuickTime supports it and (also I am not sure if it works under
Windows) supports reading and writing that data from a IEEE 1394 device (aka
FireWire or iLink).
    Thorsten
e-mail: tho### [at] trfde
Date: 13 Aug 2002 07:49:31
Message: <3d58f24b@news.povray.org>
>  Hi all,
Maybe take a look at
mplayer which contains mencoder (http://www.mplayerhq.hu/homepage/)
or
mjepgtools (http://mjpeg.sourceforge.net/)
(both linux)
or
virtualdub (www.virtualdub.org)
(windows)
I dont't know if any of them can encode to DV but if there exist a codec
(maybe from a camera manufacture) a least one of the can.
Good luck,
Sebastian H.
Date: 13 Aug 2002 10:07:56
Message: <3d5912bc@news.povray.org>
  AFAIK AVIs can contain *anything* that you can express in RIFF format.
It's just a question of having the proper codec to read and interpret the
contents of the AVI.
Date: 13 Aug 2002 10:25:38
Message: <3d5916e2@news.povray.org>
In article <3d5912bc@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
I was actually referring to a standard codec being available on all systems
as it avoids compatibility problems and such.  This suggests it would be
from Microsoft or being distributed by them.  And it does not say much about
OS support for getting DV data to or from a DV camcorder and turning it into
an avi file instantly. Of course, it depends on what exactly is needed...
    Thorsten
Date: 13 Aug 2002 10:35:14
Message: <3d591922$1@news.povray.org>
Microsoft includes a DV codec in all current builds (was it included with
DirectX 8), so an AVI file encoded for DV makes sense. I don't know how you
could call the codec from the command line, which might need to be done in
two passes: create an uncompressed AVI from your image sequence, then run
the codec on it.
Let me know if you come up with a solution.
D.
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3d5916e2@news.povray.org...
the
systems
about
into
>     Thorsten
Date: 14 Aug 2002 11:02:20
Message: <3d5a70fc@news.povray.org>
> the codec on it.
  You could use the following utility to create a raw avi and then mencoder
to convert it to DV avi (supposing you get the DV codec working with
mencoder, and why shouldn't you?):
http://oktober.stc.cx/source/animmaker.html
  (There's an example there on how to create a DivX avi; should be obviously
simple to modify in order to create a DV avi instead.)
Date: 26 Aug 2002 02:36:30
Message: <3d69cc6e@news.povray.org>
Hello Paul,
> sequential images and make an DV .avi file?
perhaps "transcode"
http://www.theorie.physik.uni-goettingen.de/~ostreich/transcode/html/modules.html
is the tool that you are looking for. Among a lot of other formats it can
read a list of images and write a DV-AVI-File.
Date: 13 Aug 2002 07:19:00
Message: <apqhlu8dffmp9aus4l6rn4kfvuoddud9fj@4ax.com>
On Tue, 13 Aug 2002 08:21:34 +0200, "Thorsten Froehlich"
>them).
You guess correctly - although the data need not have originated from
a DV camcorder.
A DV codec is included with DirectX 8 (not the best quality mind you,
but it does the job). Several video editing packages include a better
quality codec. Most of the codecs are for use with .avi files.
> but I do know that QuickTime supports it and (also I am not sure if it works under
>FireWire or iLink).
Quicktime also has a DV codec (licensed from Sorenson if I remember
correctly). This codec is for use with .mov files
The transfer to and capture from DV camcorders is a separate process
from the work the codec does. Most DV video editing packages include a
capture/transfer utility.
Cheers,
Scott
