POV-Ray : Newsgroups : povray.general : Parsing question... Server Time
24 May 2026 03:02:42 EDT (-0400)
  Parsing question... (Message 1 to 9 of 9)
Subject: Parsing question...
Date: 6 Aug 2002 16:43:55
Message: <3d50350b$1@news.povray.org>
What is actually easier for POV to parse,
(Float_Value*2) or (Float_Value+Float_Value)?
Does it make a difference? I tend to recall that
I've learned somewhere that any parser/CPU has
to do some extra job to break down the "multiply with
2" into something it can actually calculate, while
"add" is very simple and clean to do for a CPU.
Am I correct?
Tim Nikias
Email: Tim### [at] gmxde
Subject: Re: Parsing question...
Date: 6 Aug 2002 17:50:22
Message: <3d50449e@news.povray.org>
  I don't think there's any difference.
  In fact, I think that the former could be faster because a short constant
is probably faster to parse than a long identifier name (with the proper
value lookup involved).
  You have probably confused something else with this. There's no practical
difference between addition and multiplication.
Date: 6 Aug 2002 19:26:00
Message: <Xns9263DF8CAB1raf256com@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3d50449e@news.povray.org
> practical
and how about optimizing i.e.
x*x*x      <-->  pow(x,3)
x*y + x*z  <-->  x*(y+z)
sqrt(ln(pow(x,100))) + sqrt(ln(pow(x,100))) <--> 2*sqrt(ln(pow(x,100)))
etc ?
it would be very good idea to optimize functions in isosurface
Date: 6 Aug 2002 20:07:41
Message: <chrishuff-558EB0.18574106082002@netplex.aussie.org>
In article <3d50350b$1@news.povray.org>,
The differences between CPU instructions are so little compared to the
parser overhead that you probably couldn't even measure the difference,
and modern processors are so much more complex that it isn't even worth
thinking about, and modern compilers will automatically optimize many
things...the multiply by 2 might end up faster than an add.
However, for POV: the first version has fewer characters, so the current
parser would probably parse it a little more quickly. If used in a
function, there would be no noticeable difference in how fast the
function executed.
Date: 7 Aug 2002 04:56:42
Message: <r2o1lu0caeuaa2csqrtknslqehm4r6kjkf@4ax.com>
On 6 Aug 2002 19:26:00 -0400, "Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote:
that's why some optimizations are already implemented
ABX
Date: 7 Aug 2002 12:15:04
Message: <3d514788@news.povray.org>
news:3d50449e@news.povray.org...
constant
I tried a quick test, I ran through 100,000 iterations of each method in
POV, 10 times each with these results (times include trace time but that
shouldn't affect the relative outcome):
A*2
Average: 12.323s
Median: 12.315s
Max: 12.72s
Min: 11.9s
Std Dev: 0.238097
A+A
Average: 11.380s
Median: 11.395s
Max: 11.57s
Min: 11.17s
Std Dev: 0.116046
I also ran each method once with 1,000,000 iterations (i know, poor sampling
size)
A*2: 93.52s
A+A: 89.00s
It would appear that addition is quicker, but perhaps someone else should do
an independent audit.
My machine: 466MHz, 320MB, WinXP
-tgq
Date: 7 Aug 2002 15:03:27
Message: <3d516efe@news.povray.org>
TinCanMan <Tin### [at] hotmailcom> wrote:
> A+A
  You should try with longer identifier names to see if there's any
difference.
Date: 7 Aug 2002 16:17:43
Message: <chrishuff-F7AA80.15074607082002@netplex.aussie.org>
In article <3d514788@news.povray.org>,
Probably something to do with how precedence is handled in the parser.
In your test, you used 1 character identifiers, so both expressions were
the same length. I wonder how much of an effect larger identifiers would
have.
Anyway, it isn't enough of a difference to bother thinking about. If you
want to double a value, I find the N*2 to be clearer and easier to keep
up to date than the N+N version.
Date: 9 Aug 2002 14:07:29
Message: <3d5404e1@news.povray.org>
In article <3d514788@news.povray.org> , "TinCanMan"
No, it just happens that the parser checks in a certain order (from a users
point of view, I don't plan to explain how the parser works) and it so
happens that the check for multiplication and addition have to occur if a
specific order to make sure precedence is handled properly.  This says
nothing about speed of multiplication or addition...
    Thorsten
e-mail: tho### [at] trfde
