POV-Ray : Newsgroups : povray.general : using image as a function hf_macro Server Time
25 Nov 2025 19:38:23 EST (-0500)
  using image as a function hf_macro (Message 1 to 6 of 6)
Subject: using image as a function hf_macro
Date: 1 Aug 2002 13:27:11
Message: <3d496f6f$1@news.povray.org>
I would like to try the new heightfield macros using an image as the
function, but have not been able to get the syntax right. Would someone mind
posting an example?
 -Shay
Subject: Re: using image as a function hf_macro
Date: 1 Aug 2002 14:28:55
Message: <chrishuff-FADE10.13200201082002@netplex.aussie.org>
In article <3d496f6f$1@news.povray.org>, "Shay" <sah### [at] simcopartscom>
> posting an example?
function {pigment {image_map {...}}}
Date: 1 Aug 2002 15:08:50
Message: <3d498742@news.povray.org>
Christopher James Huff <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
This is what I have been trying. I am getting an error, however.
--Parse Error: Expected 'string', colour identifier found instead--
I guess I am doing something else wrong. Here is the relevant part of the
scene:
#declare ImageFunction = function {pigment {image_map {png "name2.png" }}};
#include "Shapes.inc"
HF_Square (ImageFunction,no,no,<10,10>,no,"Test_Out.inc",<-1,-1,-1>,<1,1,1>)
 -Shay
Date: 1 Aug 2002 17:57:35
Message: <chrishuff-4E3775.16484301082002@netplex.aussie.org>
In article <3d498742@news.povray.org>, "Shay" <sah### [at] simcopartscom>
> scene:
It expects a scalar float value instead of the color the pigment image
gives. Try "function {ImageFunction(x, y, z).gray}"
I thought there was another keyword that used the same algorithm the
height field object uses to get a float value from a color, but I guess
it didn't make it into the final release. The ".gray" method should be
close enough for most purposes though.
Date: 2 Aug 2002 03:04:46
Message: <3d4a2f0e@news.povray.org>
"Christopher James Huff" <chr### [at] maccom> schrieb im Newsbeitrag
The other one was .hf, which is still useable, but marked as "experimental
feature".
Marc-Hendrik
Date: 2 Aug 2002 10:35:27
Message: <3d4a98af$1@news.povray.org>
This solved the problem. Thank you for your help.
 -Shay
