POV-Ray : Newsgroups : povray.general : [3.5 Docs] 6.5.4.1 evaluate describtion Server Time
10 Sep 2025 11:53:29 EDT (-0400)
  [3.5 Docs] 6.5.4.1 evaluate describtion (Message 1 to 4 of 4)
Subject: [3.5 Docs] 6.5.4.1 evaluate describtion
Date: 19 Jul 2002 16:48:56
Message: <3d387b38@news.povray.org>
in section 6.5.4.1. the evaluate keyword is described an it says about the
three parameters:
P0: the minimum max_gradient in the estimation process,
P1: an over-estimated max_gradient value, (1 or greater)
P2: an attenuation parameter (1 or less).
Later on, the text suggests evaluate 5, 1.2, 0.95 as a start. That is: 5
(higher than 1.2) is the minimum max_gradient used, 1.2 (lower than 5) is an
over-estimated max_gradient.
Does this make any sense? Which is wrong, the suggestion for the
start-values, or the description of the parameters?
I searched p.b-t but couldn't find anything that would spread some light on
this.
Thanks in advance,
Marc-Hendrik
Subject: Re: [3.5 Docs] 6.5.4.1 evaluate describtion
Date: 20 Jul 2002 03:57:04
Message: <1ffm638.e5vjj415ig4t1N%smellenberghREMOVEME@skynet.be>
Marc-Hendrik Bremer <Mar### [at] t-onlinede> wrote:
> Hi,
> three parameters:
Indeed, the description of the P1 parameter isn't very accurate.
P1 is an over-estimating *factor*. This means that the max_gradient is
multiplied by the P1 parameter.
Also, in the evaluation process, the P1 and P2 parameters are used in
quadratic functions. This means that over-estimation increases more
rapidly with higher values and attenuation more rapidly with lower
values.
So, when you get the found max_gradient value after the first run with
the max_gradient keyword, use it with evaluate like this:
  P0 : found max_gradient * min_factor
    'min_factor' being a float between 0 and 1 to reduce the
    max_gradient to a 'minimum max_gradient'. The ideal value for P0
    would be the average of the found max_gradients, but we do not
    have access to that information.
    I usually start with 0,6 for the min_factor
  P1 : sqrt(found max_gradient/(found max_gradient * min_factor))
    'min_factor' being the same as used in P0
    this will give an over-estimation factor of more than 1, based
    on your minimum max_gradient and the found max_gradient.
  P2 : 1 or less
    I usually start with 0,7
Example: when the first run gives a found max_gradient of 356, start
with
  evaluate 356*0,6, sqrt(356/(356*0,6)), 0,7
which is actually
  evaluate 213,6, 1,29, 0,7
when getting artifacts/holes, increase the min_factor and/or P2 a bit
This method is only an approximation of what happens internally, but it
gives faster rendering speeds with the majority of isosurfaces.
e-mail:sme### [at] skynetbe
http://users.skynet.be/smellenbergh
Date: 20 Jul 2002 04:36:23
Message: <3d392107@news.povray.org>
"Rene Smellenbergh" <sme### [at] skynetbe> schrieb im Newsbeitrag
news:1ffm638.e5vjj415ig4t1N%smellenberghREMOVEME@skynet.be...
Ah thanks, that makes it much clearer now. I think, the docs should really
be changed (sometime).
Marc-Hendrik
Date: 20 Jul 2002 06:34:17
Message: <Xns92518083662AEseed7@povray.org>
I'll do so.
Ingo
