POV-Ray : Newsgroups : povray.general : fog without background Server Time
13 Jan 2026 03:19:43 EST (-0500)
  fog without background (Message 1 to 10 of 15)
Subject: fog without background
Date: 30 Jun 2002 11:36:08
Message: <3d1f2568@news.povray.org>
hello,
when i want to include fog into a scene i get following problem:
fog needs the background word. it is okay. but if i add a plane on z-axis
no fog will be rendered. it is bad, because i want to use ground fog in a
room. is there a solution for it?
thanks in advance.
Subject: Re: fog without background
Date: 30 Jun 2002 11:38:36
Message: <3d1f25fc@news.povray.org>
"marabou" <not### [at] availablenet> wrote in message
news:3d1f2568@news.povray.org...
> hello,
> thanks in advance.
Add this to your scene:
sphere {
    0,10000 // Adjust radius for scale of scene
    pigment {color rgb 0}
    hollow
...Chambers
Date: 30 Jun 2002 11:54:55
Message: <3d1f29cf@news.povray.org>
> sphere {
>     hollow
this is my code framgment and every combination brings no soulution. what
went wrong?
//----------------------------------------->>>code fragment
#declare Spere = 1;
#declare Spere = ?;
#declare Background = ?;
camera{ location <0.25,0.6,-1> look_at <0.25,0.2,0>}
light_source{
        <-1,5,-1> color <1,0.92,0.43>
light_source{
        <2,2,0.5> color White*0.5
plane{
        y,0
        pigment{
                color <1,1,1>
        normal{
                wrinkles 0.8
plane{
        z,-3
        pigment{
                color <0.16,0.63,1>
#if (Plane)
plane{
        z,1
        pigment{
                color <1,0.80,0.42>
#if (Sphere)
sphere{
        0,10000
        pigment{color rgb 0}
        hollow
#if (Background)
        background {color Blue}
fog{
        distance 0.7
        fog_type 2
        fog_offset 0.15
        fog_alt 0.05
        color <1,1,1>
//-----------------------------------------<<<code fragment
Date: 30 Jun 2002 12:22:31
Message: <3d1f3047@news.povray.org>
You need to make the plane you mentioned hollow, so that it can contain fog.
 - Slime
[ http://www.slimeland.com/ ]
Date: 30 Jun 2002 12:38:07
Message: <3d1f33ee@news.povray.org>
> fog.
this works great! but question: which side of a plane becomes hollow; where
camera is positionated or where point 0 is?
Date: 30 Jun 2002 12:57:49
Message: <3d1f388d@news.povray.org>
>> fog.
> this works great!
  But it's a kind-of wrong solution. You are defining your plane so that
everything is inside the plane, that is, you are looking at the inner
surface of the plane. You probably want to look at the outher surface of
the plane, and everything should be outside the plane (including the fog).
  That is, you have to reverse the normal and negate the offset.
  The normal points outside the plane. The other side is inside.
Date: 30 Jun 2002 19:00:25
Message: <3d1f8d89@news.povray.org>
Just a question, to confim myself:
Is this described in this way in the doc ?
I found myself a alot of times in this situation ...
Date: 30 Jun 2002 22:13:36
Message: <pan.2002.06.30.21.10.41.866879.777@mac.com>
"By definition the normal vector points to the outside of the plane..."
POV-Ray TAG e-mail: <chr### [at] tagpovrayorg>
WWW: http://homepage.mac.com/chrishuff/
Date: 1 Jul 2002 02:14:41
Message: <3d1ff351$1@news.povray.org>
shame on me
Date: 1 Jul 2002 05:09:33
Message: <3d201c4d@news.povray.org>
> fog.
i have tried it now with six planes and one plane made hollow. but then fog
is gone. why that?
