POV-Ray : Newsgroups : povray.general : transparent plane Server Time
4 Mar 2026 20:06:05 EST (-0500)
  transparent plane (Message 1 to 2 of 2)
Subject: transparent plane
Date: 19 Apr 2002 05:38:38
Message: <3cbfe59e@news.povray.org>
Hi all...
I have four points and all of them are in one plane..
Also I know the normal vector and the distance from the origin of
this plane.
How can i draw a transparent plane.? (for example red plane but can see
backward)
I've searched it from tutorials, internet and newsgroups but i couldn't
be able to find it.
Thanks...
Tanju
Subject: Re: transparent plane
Date: 19 Apr 2002 05:54:14
Message: <otpvbu8eslko3indu1h0anq84lkfk2h4ha@4ax.com>
On Fri, 19 Apr 2002 12:36:59 +0300, "Tanju Gurel" <tan### [at] ibuedutr> wrote:
> Hi all...
Hi
> I know the normal vector and the distance from the origin of this plane.
> backward)
As documentation says the syntax for plane is:
plane
        <Normal>, Distance
        [OBJECT_MODIFIERS...]
You said you have normal and distance, so just put it inside syntax.
To make it red and transparent add pigment as object modifier.
  plane{ MyNormal , MyDistance pigment{ red 1 transmit MyTransmitFactor } }
Consider also camera and light placement. It is usually necessary to see
objects :-)
> be able to find it.
Have you asked in povray.newusers ? It is designed for this kind of questions.
ABX
