POV-Ray : Newsgroups : povray.general : Random but constrained vector Server Time
4 Mar 2026 20:06:05 EST (-0500)
  Random but constrained vector (Message 1 to 5 of 5)
Subject: Random but constrained vector
Date: 17 Apr 2002 17:31:13
Message: <3cbde9a1@news.povray.org>
Given a vector <a,b,c>, how would I go about calculating a new vector within
x degrees of the original vector?
i.e. given a cone:
cone{<1,1,1>, 25, <0,0,0>,0}
a random vector within 25 degrees would lie within the cone's radius.
Subject: Re: Random but constrained vector
Date: 17 Apr 2002 17:50:28
Message: <3cbdee24@news.povray.org>
OK, given the vector:
V:  |------------>
    A            B
I'd rotate first this vector V around
any axis, that is perpendicular to V
and goes through A. Here you can use
any angle between 0 and 25 degree.
Afterwards you rotate this new vector
around the axis of the original vector V
by any random angle ...
This should work, but would merely give
an equal distribution of the results ...
So if this should be your goal, there is
probably a better method.
BTW: Are you sure, that your given Cone
Date: 18 Apr 2002 04:39:10
Message: <3cbe862e$1@news.povray.org>
"Jan Walzer" <jan### [at] lzernet> wrote in message news:3cbdee24@news.povray.org...
> V:  |------------>
>     A            B
Makes sense - god, I'm dumb.
Ah - of course it doesn't. What was I thinking? Got it into my head the 4th
param was the angle, not the radius.
Date: 18 Apr 2002 04:39:32
Message: <3cbe8644$1@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3cbde9a1@news.povray.org...
Which, of course, is nonsense....
Date: 18 Apr 2002 15:35:30
Message: <3CBF2105.69B586F6@hotmail.com>
> within x degrees of the original vector?
Depends on what kind of distribution you want.  If the vectors in the
cone are equally likely, the method is different from, say, having the
ones around the center be more likely than the rest.
John
Rusty is rendering!
