POV-Ray : Newsgroups : povray.general : intersection points..... Server Time
27 Nov 2025 10:43:53 EST (-0500)
  intersection points..... (Message 1 to 8 of 8)
Subject: intersection points.....
Date: 16 Apr 2002 15:41:53
Message: <3cbc7e81@news.povray.org>
hi...
I have 14 planes with their normal vectors and distances from origin...
Using intersection{} i had intersected them.
then my object has constructed....
but i need the intersection points of the planes....
because i want to put spheres at that locations
Is there any variable or method to get them from povray?
thanks.
Tanju
Subject: Re: intersection points.....
Date: 16 Apr 2002 15:56:11
Message: <3cbc81db@news.povray.org>
maybe it's a chance, if you insect 3 planes, and then use the
min/max_extend-functions... it could be, that one of the ext-
ends gives you the point, you're looking for ...
... but you'd have to do this for every corner of your obj.
don't count on this, to work at all, as this is probably only
a silly idea, that flashed through my mind, when I read your
post ...
Date: 16 Apr 2002 16:11:36
Message: <3CBC8578.548F0ED0@gmx.de>
Won't work, min/max_extend only gives the extents of the bounding box, if
you don't bound the intersection manually this won't even give a usable
result.
But of course it should not very difficult to calculate the intersection
of the planes with some basic math.
http://mathworld.wolfram.com/Plane-PlaneIntersection.html
Last updated 14 Apr. 2002 _____./\/^>_*_<^\/\.______
Date: 16 Apr 2002 16:32:09
Message: <3cbc8a49@news.povray.org>
news:3CBC8578.548F0ED0@gmx.de...
> result.
> Christoph
> POV-Ray tutorials, IsoWood include,
> TransSkin and more: http://www.tu-bs.de/~y0013390/
i've calculated the points
with 14 planes there is 600 intersection points but i could not be able to
find
the way to eliminate them....
here is the object.....
http://vancat.ibu.edu.tr/bz.jpg
tanju
Date: 16 Apr 2002 16:35:00
Message: <3CBB397C.D7AC06EA@hotmail.com>
Hi Tanju.
Here's some suggestions:
Every possible combination of 3 planes from your
set of 14 planes should be tested for a common
point (or line or plane). (But note that not every
found point will be on the surface of your
intersection of planes shape).
If vPl1, vPl2 and vPl3 are the normal vectors
for each of the planes and pPl1, pPl2 and pPl3 are
arbitrary points on each plane, then this code will
help you find the intersection points for a plane-
triple:
#if (vdot(vPl1, vcross(vPl2, vPl3) != 0)
  #declare pInterSect =
    pl2pl2pl(pPl1, vPl1, pPl2, vPl2, pPl3, vPl3)
#else
  #error "No singe point of intersection"
#end // if
If you don't know any pPl1, pPl2 or pPl3 points,
then you can calculate some with these expressions:
#declare pPl1 = Distt1*vnormalize(vPl1);
#declare pPl2 = Distt2*vnormalize(vPl2);
#declare pPl3 = Distt3*vnormalize(vPl3);
Where Dist1, Dist2 and Dist3 are the distances from
each of the planes to origo (like POV-Ray expects
in its plane {} expressions).
My pl2pl2pl() macro can be found within this post:
"Re: general geometry question" posted 22. Aug.-01
to this group:
http://news.povray.org/povray.general/17701/114420/
news://news.povray.org/3B82F267.36412849%40hotmail.com
If you want go the other way, you can do this:
#declare Dist1 = vdot(pPl1, vnormalize(vPl1));
#declare Dist2 = vdot(pPl2, vnormalize(vPl2));
#declare Dist3 = vdot(pPl3, vnormalize(vPl3));
Feel free to ask more if you need further help.
Tor Olav
Tanju Gurel wrote:
> hi...
> thanks.
> Tanju
Date: 16 Apr 2002 16:49:58
Message: <3CBB3CFE.338FA35C@hotmail.com>
> find
You now have to check every point you found
to see if it has any planes "below" it (i.e.
between it and origo.) If it has, then it is
not on the surface of your shape.)
I've earlier worked with this problem myself.
See my post: "Concave shapes"
(to povray.binaries.images 5. Okt.-00)
http://news.povray.org/povray.binaries.images/12996/
news://news.povray.org/39DC993C.5D889A93%40online.no
Tor Olav
Date: 16 Apr 2002 16:55:35
Message: <3CBB3E4F.9A7E7CF4@hotmail.com>
> > find
Sorry. This is only true if you have "put"
origo inside your shape.
Tor Olav
Date: 17 Apr 2002 04:26:27
Message: <3cbd31b3@news.povray.org>
"Tor Olav Kristensen" <tor### [at] hotmailcom> wrote in message
news:3CBB3E4F.9A7E7CF4@hotmail.com...
able to
> > > find
> Tor Olav
thanks to all....
i've done it...
http://vancat.ibu.edu.tr/chbz.jpg
have a nice day....
