![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This version fixes some bugs with evaluating expressions mixing scalars
and vectors, and plugs a fairly big memory leak. I've also added a lot
of other goodies...new functions, more operators, a random number
generator using the Mersene Twister algorithm, graphing tools, several
particle simulation demos...
Still need a Unix makefile, any volunteers?
Feedback, please! Questions, comments, suggestions, flames, anything...
Christopher James Huff <chr### [at] mac com>
POV-Ray TAG e-mail: chr### [at] tag povray org
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Location of same? :)
Grim
"Christopher James Huff" <chr### [at] mac com> wrote in message
news:chr### [at] netplex aussie org...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3cafc1c1@news.povray.org>,
Same as before:
http://homepage.mac.com/chrishuff/csdl/csdl.html
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thank you, missed the last posting I guess ;)
Grim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
After having the previously mentioned troubles downloading the files i had
errors compiling 'csdl_engine.cpp', 'csdl_streams.cpp' and
'csdl_stdlib.cpp':
g++ -c -Wall -o csdl_engine.o csdl_engine.cpp
csdl_engine.cpp: In method `class istream *
csdl::CSDL_Engine::OpenFile(const string &)':
csdl_engine.cpp:82: no matching function for call to
`vector<basic_string<char,string_char_traits<char>,__default_alloc_template<false,0>
>,allocator<basic_string<char,string_char_traits<char>,__default_alloc_template<false,0>
> > >::at (int &)'
g++ -c -Wall -o csdl_streams.o csdl_streams.cpp
csdl_streams.cpp: In method `class csdl::Data *
csdl::Stream_Read_Fn::Run()':
csdl_streams.cpp:31: no matching function for call to `vector<csdl::Data
*,allocator<csdl::Data *> >::at (int &)'
csdl::Stream_Write_Fn::Run()':
csdl_streams.cpp:38: no matching function for call to `vector<csdl::Data
csdl::Stream_Open_Fn::Run()':
csdl_streams.cpp:45: no matching function for call to `vector<csdl::Data
*,allocator<csdl::Data *> >::at (int)'
csdl_streams.cpp:46: no matching function for call to `vector<csdl::Data
g++ -c -Wall -o csdl_stdlib.o csdl_stdlib.cpp
csdl_stdlib.cpp: In method `class csdl::Data * csdl::SystemFn::Run()':
csdl_stdlib.cpp:31: no matching function for call to `vector<csdl::Data
csdl_stdlib.cpp: In method `class csdl::Data * csdl::MinFn::Run()':
csdl_stdlib.cpp:39: no matching function for call to `vector<csdl::Data
csdl_stdlib.cpp:41: no matching function for call to `vector<csdl::Data
csdl_stdlib.cpp: In method `class csdl::Data * csdl::MaxFn::Run()':
csdl_stdlib.cpp:49: no matching function for call to `vector<csdl::Data
csdl_stdlib.cpp:51: no matching function for call to `vector<csdl::Data
csdl_stdlib.cpp: In method `class csdl::Data * csdl::VLengthFn::Run()':
csdl_stdlib.cpp:59: no matching function for call to `vector<csdl::Data
csdl_stdlib.cpp: In method `class csdl::Data * csdl::VLengthSqrFn::Run()':
csdl_stdlib.cpp:66: no matching function for call to `vector<csdl::Data
csdl_stdlib.cpp: In method `class csdl::Data * csdl::VNormalizeFn::Run()':
csdl_stdlib.cpp:73: no matching function for call to `vector<csdl::Data
csdl_stdlib.cpp: In method `class csdl::Data * csdl::VDotFn::Run()':
csdl_stdlib.cpp:80: no matching function for call to `vector<csdl::Data
csdl_stdlib.cpp: In method `class csdl::Data * csdl::VCrossFn::Run()':
csdl_stdlib.cpp:87: no matching function for call to `vector<csdl::Data
csdl::FnRNGObjectSeed::Run()':
csdl_stdlib.cpp:156: no matching function for call to `vector<csdl::Data
csdl_stdlib.h: In method `class csdl::Data *
csdl::Fn2ScalarRtScalar<double>::Run()':
csdl_function.h:88: instantiated from here
csdl_stdlib.h:129: no matching function for call to `vector<csdl::Data
csdl::Fn1ScalarRtScalar<double>::Run()':
csdl_stdlib.h:114: no matching function for call to `vector<csdl::Data
Last updated 18 Mar. 2002 _____./\/^>_*_<^\/\.______
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3CB015E3.65C0F697@gmx.de>,
> 'csdl_stdlib.cpp':
Ah, don't you just love template errors? :-/
It seems to be choking on the STL vector "at()" method...I have no idea
why, it is standard. What version compiler and libraries are you using?
Anyone else have any ideas?
Try replacing "libPaths.at(j)" with "libPaths[j]" in csdl_engine.cpp,
and "parameters->at(j)" with "(*parameters)[j]" in the others.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
...snip...
Still having problems? :-(
What exactly were the problems? The line endings didn't give you any
trouble, did they?
Well, at least you were still able to get them. Maybe I should get
around to setting up my Earthlink account web site as a mirror...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
At least gcc 2.x does not support the standard in this case (I haven't
the slightest idea why).
I don't know about gcc 3.x (I haven't tried).
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3cb0acc3@news.povray.org>, Warp <war### [at] tag povray org>
I'm developing it using Apple's modified version of gcc 2.95.2.
Obviously, vector::at() works here...maybe Apple fixed that part.
It seems like such a simple and basic thing that it would be surprising
for even the least complete and compliant implementation to lack it. In
the next version I'll use the [] operator instead...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
gcc 2.95.3-5
It compiled correctly with that modifications.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
