![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Is there any built in way to find the exact length of a spline in POV 3.5?
A linear spline would be easy enough, but with the curves it may be a bit
more difficult... Surely POV has some intrnal function to figure it out,
but is there a way to find the length of a random spline at run-time?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Barron Gillon wrote in message <3cacf454@news.povray.org>...
POV-Ray doesn't know or care about the length of a spline. In fact, I don't
know if it's even possible to calculate the exact length of a cubic or
natural spline.
Mark
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Mark Wagner <mar### [at] gte net> replied:
don't
> natural spline.
I don't believe it is - from my studies of splines a while back it seems the
integration of the relevant functions just isn't possible. The easiest way
to find a spline's length, then, is probably sampling linear distances at
steps along the spline. Also, a rough approximation can be calculated using
the bezier hull length. My own Spline Macro File
(http://www.geocities.com/ccolefax) uses both methods to allow returning the
length of splines and other features like constant-speed traversing of
spline paths.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Chris Colefax <chr### [at] tag povray org> wrote:
> The easiest way
Isn't the main problem with this that it always returns a value which
is too small? (Although usually it doesn't matter as long as it's close
enough to the true value...)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
probably ...
because, if you do a linear-interpolation between the two points,
it is quite uncertain, that the way-on-spline is shorter ... No?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
A line is the shortest distance between two points. This means that any
other path is longer. Thus the spline can never be shorter than the linear
estimate. As a spline seldom consists of straight lines (except for the
linear spline), it's always longer than the linear estimate.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Chris Colefax" <chr### [at] tag povray org> wrote in message
news:3cad4420@news.povray.org...
using
Is it the same approximation method as mentioned in
http://research.microsoft.com/~hollasch/cgindex/curves/cbezarclen.html ?
Gleb
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
seems we're telling each other to be right ...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> seems the integration of the relevant functions just isn't possible.
A quadratic spline
P(x) = Ax^2 + Bx + C
has the derivative in x of
dP(x)/dx = 2Ax + B
which has a magnitude of
sqrt( 4(A.A)x^2 + 4(A.B)x + (B.B) ),
which can be integrated over x (the integral is in my calc book).
A cubic spline,
P(x) = Ax^3 + Bx^2 + CX + D
Will have a quadratic derivative in x, namely
dP/dx = 3Ax^2 + 2Bx + C
The magnitude of which is
|dP/dx| = sqrt( 9(A.A)x^4 + 12(A.B)x^3 + 4(B.B)x^2 + 6(A.C)x^2
+ 4(B.C)x + (C.C) )
Dunno if this can be integrated over x. Taylor's expansion might
provide a clue to the integral.
John
Rusty is rendering!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I wasn't saying "no, you are wrong, it's this way". I was just profundizing
in the subject. :)
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
