POV-Ray : Newsgroups : povray.general : spline length? Server Time
29 Dec 2025 18:15:26 EST (-0500)
  spline length? (Message 1 to 10 of 12)
Subject: spline length?
Date: 4 Apr 2002 19:48:20
Message: <3cacf454@news.povray.org>
Is there any built in way to find the exact length of a spline in POV 3.5?
A linear spline would be easy enough, but with the curves it may be a bit
more difficult...  Surely POV has some intrnal function to figure it out,
but is there a way to find the length of a random spline at run-time?
Subject: Re: spline length?
Date: 5 Apr 2002 01:19:54
Message: <3cad420a@news.povray.org>
Barron Gillon wrote in message <3cacf454@news.povray.org>...
POV-Ray doesn't know or care about the length of a spline.  In fact, I don't
know if it's even possible to calculate the exact length of a cubic or
natural spline.
Mark
Date: 5 Apr 2002 01:28:48
Message: <3cad4420@news.povray.org>
Mark Wagner <mar### [at] gtenet> replied:
don't
> natural spline.
I don't believe it is - from my studies of splines a while back it seems the
integration of the relevant functions just isn't possible.  The easiest way
to find a spline's length, then, is probably sampling linear distances at
steps along the spline.  Also, a rough approximation can be calculated using
the bezier hull length.  My own Spline Macro File
(http://www.geocities.com/ccolefax) uses both methods to allow returning the
length of splines and other features like constant-speed traversing of
spline paths.
Date: 5 Apr 2002 06:07:19
Message: <3cad8567@news.povray.org>
Chris Colefax <chr### [at] tagpovrayorg> wrote:
> The easiest way
  Isn't the main problem with this that it always returns a value which
is too small? (Although usually it doesn't matter as long as it's close
enough to the true value...)
Date: 5 Apr 2002 08:46:54
Message: <3cadaace@news.povray.org>
probably ...
because, if you do a linear-interpolation between the two points,
it is quite uncertain, that the way-on-spline is shorter ...   No?
Date: 5 Apr 2002 10:20:57
Message: <3cadc0d8@news.povray.org>
  A line is the shortest distance between two points. This means that any
other path is longer. Thus the spline can never be shorter than the linear
estimate. As a spline seldom consists of straight lines (except for the
linear spline), it's always longer than the linear estimate.
Date: 5 Apr 2002 10:35:00
Message: <3cadc424$1@news.povray.org>
"Chris Colefax" <chr### [at] tagpovrayorg> wrote in message
news:3cad4420@news.povray.org...
using
Is it the same approximation method as mentioned in
http://research.microsoft.com/~hollasch/cgindex/curves/cbezarclen.html  ?
Gleb
Date: 5 Apr 2002 10:51:38
Message: <3cadc80a@news.povray.org>
seems we're telling each other to be right ...
Date: 5 Apr 2002 13:36:42
Message: <3CADEFA0.F3015659@hotmail.com>
> seems the integration of the relevant functions just isn't possible.
A quadratic spline
  P(x) = Ax^2 + Bx + C
has the derivative in x of
  dP(x)/dx = 2Ax + B
which has a magnitude of
  sqrt( 4(A.A)x^2 + 4(A.B)x + (B.B) ),
which can be integrated over x (the integral is in my calc book).
A cubic spline,
  P(x) = Ax^3 + Bx^2 + CX + D
Will have a quadratic derivative in x, namely
  dP/dx = 3Ax^2 + 2Bx + C
The magnitude of which is
  |dP/dx| = sqrt( 9(A.A)x^4  + 12(A.B)x^3 +  4(B.B)x^2 +  6(A.C)x^2
     +  4(B.C)x +   (C.C) )
Dunno if this can be integrated over x.  Taylor's expansion might
provide a clue to the integral.
John
Rusty is rendering!
Date: 6 Apr 2002 07:41:55
Message: <3caeed12@news.povray.org>
  I wasn't saying "no, you are wrong, it's this way". I was just profundizing
in the subject. :)
