POV-Ray : Newsgroups : povray.general : function question Server Time
23 Apr 2026 05:11:45 EDT (-0400)
  function question (Message 1 to 10 of 16)
Subject: function question
Date: 3 Apr 2002 16:20:36
Message: <3cab7224$1@news.povray.org>
Can I define a function that takes a float and returns a vector?
Something like this:
function Get_Vec {<x^2,x^3,x^4>}
Get_Vec (2) ------> <4,8,16>
Do I have to use a macro to accomplish this?
 -Shay
Subject: Re: function question
Date: 3 Apr 2002 16:24:26
Message: <dismau0b4okcpjbttn20s9pc7lhftp9smo@4ax.com>
Not directly but there is possible workaround.
If it is called only at parse time then macro version could be simpler to code.
ABX
Date: 3 Apr 2002 16:33:59
Message: <3cab7547@news.povray.org>
No.
Either that or something like:
#declare vec = <Get_VecX(2),Get_VecY(2),Get_VecZ(2)>;
Jonathan.
Home: http://digilander.iol.it/jrgpov
Date: 3 Apr 2002 16:37:06
Message: <3cab7602@news.povray.org>
Thanks, guys. I'm going to have to time the workaround against a macro. I am
thinking of building combination fractal / 3D knots so speed is a very
important consideration.
 -Shay
Shay <sah### [at] simcopartscom> wrote in message
news:3cab7224$1@news.povray.org...
Date: 3 Apr 2002 16:37:22
Message: <3cab7612@news.povray.org>
You mean some cyiptic code?
Jonathan.
Date: 3 Apr 2002 16:40:39
Message: <ljtmauofa469e877m395m9e19pl5fl8djj@4ax.com>
It depends what you mean as cyiptic.
ABX
Date: 3 Apr 2002 16:43:15
Message: <3cab7773@news.povray.org>
> ABX
Oops, I meant "cryptic".
Jonathan.
Date: 3 Apr 2002 17:12:44
Message: <jltmaukpci64s7497l1qdr79asqpl6tpln@4ax.com>
// at first you have to code functions for each component of your vector
// sample operations attached
#local f_X = function ( float ) { float };
#local f_Y = function ( float ) { float/2 };
#local f_Z = function ( float ) { float/3 };
// then you have to bound possible results
// bounding can be pretty large but remember about accuracy problem
#local X_Min = -10000;
#local X_Max = 2560;
#local Y_Min = 1000;
#local Y_Max = 1280;
#local Z_Min = 1000;
#local Z_Max = 3300;
// then you have to calculate ranges of coordinates
#local X_Range = X_Max - X_Min;
#local Y_Range = Y_Max - Y_Min;
#local Z_Range = Z_Max - Z_Min;
// now create pigment inside ranges
// our float is supposed to be at x coordinate position
#local P = pigment{
  average
  pigment_map{
      1
      function { ( f_X(x) - X_Min ) / X_Range }
      color_map { [0 red 3*X_Min] [ 1 red 3*(X_Range+X_Min) ] }
      1
      function { ( f_Y(x) - Y_Min ) / Y_Range }
      color_map { [0 green 3*Y_Min] [ 1 green 3*(Y_Range+Y_Min) ] }
      1
      function { ( f_Z(x) - Z_Min ) / Z_Range }
      color_map { [0 blue 3*Z_Min] [ 1 blue 3*(Z_Range+Z_Min) ] }
// now convert pigment to function
#local F=function{pigment{P}};
// finally call function putting float at x position and putting anything
// (for example 0) at x and y position
#local V = F(300,0,0);
// remember result is 5D vector (color) so before use as 3D recconvert it
#include "strings.inc"
#warning VStr( <V.x,V.y,V.z> )
// ABX
// I hope I will be considered as the father of this method ;-)
Date: 3 Apr 2002 17:16:19
Message: <0ovmauor2afad073nh0s42uhjjv5qqq2gg@4ax.com>
It depends what you mean as cryptic.
Anyway code after moment in this thread so You'll see it is cryptic or not.
ABX
Date: 3 Apr 2002 17:21:02
Message: <vvvmaus0bvr1jq81bl52sdf4nsqvlvb6cm@4ax.com>
should be rather
#local Y_Min = -1000;
#local Z_Min = -100;
ABX
