POV-Ray : Newsgroups : povray.general : Sor / Lathe Discrepancy? (Image on binaries.images) Server Time
23 Apr 2026 06:49:43 EDT (-0400)
  Sor / Lathe Discrepancy? (Image on binaries.images) (Message 1 to 2 of 2)
Subject: Sor / Lathe Discrepancy? (Image on binaries.images)
Date: 26 Mar 2002 15:44:15
Message: <3ca0dd9f$1@news.povray.org>
After reading through some of the source code for PovRay, I discovered that
(I think) Sor's and Lathe's use cubic splines to calculate their points. But
after rendering the following scene, where each lathe uses the same point
setup as each sor, I am confused.
What method does sor use to calculate splines? (Image on binaries.images)
 #declare myLathe = lathe {
   cubic_spline
   7,
   <0, -5>, //Control Point
   <.8, -.3>,
   <.2, 0>,
   <.3, .3>,
   <.5, .5>,
   <.2, .6>,
   <0, 5> //Control Point
   sturm
   pigment {color rgb<1, 0, 0>}
 #declare mySor = sor {
   7,
   <.8, -.3>,
   <.2, 0>,
   <.3, .3>,
   <.5, .5>,
   <.2, .6>,
   pigment {color rgb<1, 1, 1>}
   sturm
object {myLathe translate x*1}
object {mySor translate x*-1}
object {myLathe rotate x*-70 translate <1, 1.5, 3>}
object {mySor rotate x*-70 translate <-1, 1.5, 3>}
Subject: Re: Sor / Lathe Discrepancy? (Image on binaries.images)
Date: 26 Mar 2002 16:22:14
Message: <3ca0e686@news.povray.org>
Lathes and sors obviously use different algorithms for calculating the
splines because sors are more limited than lathes. Thus it's not a
surprise that they look different with the sample control points.
