POV-Ray : Newsgroups : povray.general : Collision detection Server Time
19 Jun 2026 06:32:52 EDT (-0400)
  Collision detection (Message 1 to 4 of 4)
Subject: Collision detection
Date: 2 Mar 2002 15:03:57
Message: <3c81302d@news.povray.org>
Does anyone have any suggestions as to how I would go about detecting a
collision between an edge of a triangle and an object? vertex collision is
easy but the edge detection completly confuses me, I've had some ideas but
none of them are very practical, and they don't give me the point of
intersection.
Kevin
Subject: Re: Collision detection
Date: 2 Mar 2002 15:24:37
Message: <chrishuff-F735D5.15244202032002@netplex.aussie.org>
In article <3c81302d@news.povray.org>, "Kevin Loney" <klo### [at] pt2mcom>
> intersection.
Use trace() along the edge of the triangle, if the distance to the
intersection is less than the length of the edge, the edge collides with
the object.
Date: 2 Mar 2002 15:38:49
Message: <3c813859$1@news.povray.org>
I've considered that method which is by far the easiest but it won't work
very well for a cloth because I need to find the exact point of collision so
I can calculate accurate bounce.
Kevin
Date: 2 Mar 2002 20:24:05
Message: <chrishuff-E8DC38.20240202032002@netplex.aussie.org>
In article <3c813859$1@news.povray.org>,
If you mean to find the point the side first hit the object, there is no
way to do that exactly. You would have to use infinitely many steps.
However, you could do the tracing from both ends of the side, and pick a
point in the middle of the two intersections for a slightly more
accurate approximation. Or take the last position of the edge and the
current position, and perform several samples to get a better result. I
think the best solution is just a higher resolution cloth and smaller
step values though.
