POV-Ray : Newsgroups : povray.general : Height fields in isos (3.5) Server Time
30 Dec 2025 03:34:16 EST (-0500)
  Height fields in isos (3.5) (Message 1 to 9 of 9)
Subject: Height fields in isos (3.5)
Date: 12 Feb 2002 07:05:30
Message: <3c69050a@news.povray.org>
have I imagined it, or can you use an hf as a pigment and then use that in an
iso-function?
If so, can someone post a quick example?
#macro G(D,E,F)#local I=array[3]{D,E,F}#local B=0;triangle{#while(
B<3)#while(I[B])A[mod(I[B],10)]+#local I[B]=div(I[B],10);#end<-5,-
2,9>#local B=B+1;#end}#end #local A=array[7]{x,x*2,x*4,y,y*2,y*4,z
}light_source{-x*6-z*9,1}mesh{G(105,10,146)G(105,246,10)G(105,56,
146)G(105,1256,246)G(1256,126,220)G(22156,2216,201)pigment{rgb 1}}//TM
Subject: Re: Height fields in isos (3.5)
Date: 12 Feb 2002 07:32:30
Message: <3C690B55.2AE3439C@namtar.qub.ac.uk>
I tried to use this in my IRTC entry, but it produces the blocky hf
effect we're all familiar with, plus you can't use the smooth keyword
anymore. On the upside, you can use non-flat blocks by adding a smooth
function...
> iso-function?
signature{
Date: 12 Feb 2002 07:36:30
Message: <3c690c4e$1@news.povray.org>
"Grey Knight" <s16### [at] namtarqubacuk> wrote in message
news:3C690B55.2AE3439C@namtar.qub.ac.uk...
> function...
Well, I'm already csg'ing my hf with an iso, so I assume the "smooth" keyword is
already defunct (assuming it's just a normal pertubation).
Date: 12 Feb 2002 07:37:48
Message: <3C690C98.73644E17@gmx.de>
> iso-function?
You obviously cannot use a heightfield in an isosurface, but of course you
can use an image_map/image_pattern is an isosurface function just like any
other pigment/pattern.  Make sure you use 'interpolate 2', otherwise you
will get problems with the gradient.
The following should give an idea (not tested)
#declare fn_Img=function {
    image_map {
      png "file.png"
      map_type 0
      interpolate 2
      once
#declare fn_iso=function {
  z - fn_Img(x, y, 0).gray*0.1
Last updated 06 Feb. 2002 _____./\/^>_*_<^\/\.______
Date: 12 Feb 2002 07:44:11
Message: <3c690e1b$1@news.povray.org>
news:3C690C98.73644E17@gmx.de...
Many thanks...
Date: 12 Feb 2002 07:46:57
Message: <3c690ec1@news.povray.org>
Grey Knight <s16### [at] namtarqubacuk> wrote:
: I tried to use this in my IRTC entry, but it produces the blocky hf
: effect we're all familiar with
  Did you use 'interpolate 2'?
Date: 12 Feb 2002 07:49:49
Message: <343i6uggabpj4hd1vgrimssib8pq0hh5ol@4ax.com>
On Tue, 12 Feb 2002 12:05:25 -0000, "Tom Melly" <tom### [at] tomandlucouk> wrote:
> iso-function?
Add this to command box:
Library_Path="C:\Program Files\POV-Ray for Windows v3.5\scenes\portfolio"
+Iallobjects.pov +KFI9 +KFF9
ABX
Date: 12 Feb 2002 08:10:07
Message: <3C691425.2A3587C9@namtar.qub.ac.uk>
Didn't play around with it for very long; I figured out a way to get the
same shape (sans blocks) procedurally, so...
signature{
Date: 12 Feb 2002 16:58:53
Message: <3c69901d@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3c69050a@news.povray.org...
> iso-function?
Here is another example.
http://news.povray.org/3bdbbdb2@news.povray.org
R. Suzuki
