POV-Ray : Newsgroups : povray.general : Line-Plane intersection Server Time
24 Mar 2026 03:21:50 EDT (-0400)
  Line-Plane intersection (Message 1 to 10 of 11)
Subject: Line-Plane intersection
Date: 7 Feb 2002 23:01:33
Message: <3c634d9d$1@news.povray.org>
How can I figure out where a given line defined by two points intersects a
plane defined by three points?
Thank you, -Shay
Subject: Nevermind, figured out a way.
Date: 8 Feb 2002 00:42:01
Message: <3c636529$1@news.povray.org>
Subject: Re: Nevermind, figured out a way.
Date: 8 Feb 2002 03:16:48
Message: <m2276u8cjfukndhp0nn3vtvv0v1f3e4n4q@4ax.com>
On Fri, 8 Feb 2002 11:37:57 -0800, "Shay" <shi### [at] houstonrrcom> wrote:
1. Please do not send empty posts.
2. Please just cancel your posts if they are no more valid.
Thank You
ABX
Date: 8 Feb 2002 09:44:50
Message: <3c63e462@news.povray.org>
Tell me how outlook express and consider it done.
 -Shay
news:m2276u8cjfukndhp0nn3vtvv0v1f3e4n4q@4ax.com...
> Thank You
> ABX
Date: 8 Feb 2002 09:48:51
Message: <3c63e553$1@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message news:3c63e462@news.povray.org...
Too late! (you've had replies).
For future ref:
select message and go to message/cancel message
Anyway, it's not so bad - someone might see you message, run into the same
problem, and mail you or post to ask how you resolved it....
Date: 8 Feb 2002 10:33:22
Message: <rpr76u8dm8jj42kq8f07jep2staov99ncp@4ax.com>
On Fri, 8 Feb 2002 08:45:29 -0600, "Shay" <sah### [at] simcopartscom> wrote:
>Tell me how
AFAIK there is a help (aka manual) in MS Outlook Express
ABX
Subject: Re: Line-Plane intersection
Date: 9 Feb 2002 07:01:56
Message: <3C650F3B.8030308@skynet.be>
Within POV-Ray, you could simply use "trace"...
Fabien.
Date: 9 Feb 2002 10:45:17
Message: <3c65440d@news.povray.org>
That's not a good idea. People might download and see the message before
it's cancelled and then spend time writing a reply. OE doesn't show if a
message has been cancelled.
But besides, whenever you ask a question and then find the answer yourself,
please tell what it was. Other's might be interested.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Jan 20)
Date: 11 Feb 2002 12:09:59
Message: <3c67fae7@news.povray.org>
Trace would have been the best way, math the second. I did it the worst way
(too long at the computer makes your brain go funny.)
I rotated the whole problem onto the x plane and extended my vector to y=0.
 -Shay
Shay <shi### [at] houstonrrcom> wrote in message
news:3c634d9d$1@news.povray.org...
> Thank you, -Shay
Date: 12 Feb 2002 14:06:37
Message: <3C696707.3F9BF78E@spiritone.com>
I answered your question anyway:
The following macro should calculate the intersection if it exists
Note that it does not determine if the line intersects the triangle
defined by your three points. If the line segment doesn't intersect the
plane it will still find the solution
#declare pa = <-1,-1,-1>;
#declare pb = <1,0,1>;
#declare pc = <-1,0,0>;
triangle { pa pb pc pigment { rgbf <1,1,0,0.5> } }
#declare la = <1,1,1>;
#declare lb = <-0.5,-1,-0.2>;
cylinder { la lb 0.01 pigment { rgb x } }
#macro PlaneAndLine(a,b,c,d,e)
  // a,b,c are on the plane
  // d and e are on the line
  #local pn = vnormalize(vcross(a-b,c-b));
  #local ld = vnormalize(d-e);
  #local test = vdot(ld,pn);
  #local ps = <0,0,0>;
  #if ( abs(test) < 0.00001 )
     #debug "Line does not intersect plane"
  #else
     #local mu = vdot((a-d),pn)/vdot(ld,pn);
     #local ps = d + mu*ld;
  ps
#declare ps = PlaneAndLine(pa,pb,pc,la,lb);
sphere { ps 0.05 pigment { rgb y } }
Josh English
eng### [at] spiritonecom
http://www.spiritone.com/~english
