POV-Ray : Newsgroups : povray.general : image sequence Server Time
16 Jul 2026 13:30:39 EDT (-0400)
  image sequence (Message 1 to 5 of 5)
Subject: image sequence
Date: 6 Feb 2002 14:50:09
Message: <3c6188f1$1@news.povray.org>
I'd like to read in a different targa file for every frame of an animation
and use it in a height field. Can someone tell me the syntax for reading a
sequence starting with, say, fig001.tga?
The code would be used here:
height_field {
 tga "d:\fig001.tga"
 smooth
 scale <1,-1,1>
 translate y
Thanks very much.
Dennis
dhm### [at] mediaonenet
www.casdn.neu.edu/~dmiller
Subject: Re: image sequence
Date: 6 Feb 2002 15:51:56
Message: <3C61976A.4ED3F048@gmx.de>
try something like:
concat("fig", str(clock*100,-2,0), ".tga")
in POV 3.5 you can also use 'frame_number'.
Last updated 06 Feb. 2002 _____./\/^>_*_<^\/\.______
Date: 6 Feb 2002 16:01:29
Message: <3c6199a8@news.povray.org>
Dennis Milller <dhm### [at] mediaonenet> wrote:
: I'd like to read in a different targa file for every frame of an animation
: and use it in a height field. Can someone tell me the syntax for reading a
: sequence starting with, say, fig001.tga?
  You should read the documentation about string functions, specially
concat() and str().
  What you want is something like
concat("fig", str(frame_number,-3,0), ".tga")
Date: 6 Feb 2002 16:52:38
Message: <3c61a5a6$1@news.povray.org>
Yes, I'm sorry, I just don't know quite how to apply it to the HF:
This doesn't work:
height_field {
 tga concat("fig", str(clock*100,-2,0), ".tga")
 smooth
 scale <1,-1,1>
 translate y
nor does this:
height_field {
 smooth
 scale <1,-1,1>
 translate y
Could you show me the line in this context?
thanks again,
Dennis
news:3c6199a8@news.povray.org...
animation
a
> concat() and str().
M()}}
Warp -
Date: 6 Feb 2002 17:37:41
Message: <3c61b035@news.povray.org>
I'm sorry to sound *sarcastic*, but did you try to understand how does
it work?
  Hint: You probably need to add the path to the location of the tga files,
as you have in your original example.
