POV-Ray : Newsgroups : povray.general : clipped_by ... Server Time
13 Jan 2026 20:53:50 EST (-0500)
  clipped_by ... (Message 1 to 10 of 10)
Subject: clipped_by ...
Date: 13 Jan 2002 16:42:44
Message: <3c41ff54@news.povray.org>
Can I add a temporary texture to 'clipped_by' so that I can see a little
more clearly what I'm doing? It's driving me nuts!!  ;)
   ATM, I'm just trying to cut a round hole in a box, but instead of a hole
in the box, I'm getting a circle of the box' texture.
  Where am I going wrong with this?
  object{
box {
  <-1.3, -1.3, -1.3>
  < 1.3,  1.3,  1.3>
 translate <0, 1, 5>}
texture {T_Stone20}
 clipped_by {sphere { <0, 1, 3> .8 }}}
   ~Steve~
Subject: Re: clipped_by ...
Date: 13 Jan 2002 17:04:57
Message: <3C4204B6.CEC7F316@engineer.com>
clipped_by {sphere { <0, 1, 3> .8 inverse}}}
_____________
Kari Kivisalo
Date: 13 Jan 2002 17:22:34
Message: <3c4208aa@news.povray.org>
Remember, clipped_by works like intersection, not like difference.
Date: 13 Jan 2002 17:36:03
Message: <3c420bd3$1@news.povray.org>
news:3c4208aa@news.povray.org...
      Thanks Warp, I'm just practising with this at the moment. I want to
put a hole in a door and add one of those 'spy-holes'. The lens may be
difficult though.
    ~Steve~
x]
Warp -
Date: 13 Jan 2002 17:36:05
Message: <3c420bd5@news.povray.org>
"Kari Kivisalo" <ray### [at] engineercom> wrote in message
news:3C4204B6.CEC7F316@engineer.com...
     Thanks Kari, worked a treat. :)
       ~Steve~
> _____________
> Kari Kivisalo
Date: 13 Jan 2002 18:00:54
Message: <chrishuff-9A3F8D.18014013012002@netplex.aussie.org>
In article <3c420bd3$1@news.povray.org>, "25ct" <25c### [at] lineonenet>
> difficult though.
This sounds like difference would be a better choice anyway...what was
your reason for using clipped_by?
Date: 13 Jan 2002 18:23:50
Message: <3c421706@news.povray.org>
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
to
> > difficult though.
    Just to put a hole in a door so that I can add the spy-hole, eg, a lens
and surrounding fittings.
    Is there another way Chris? What would difference do?
       ~Steve~
Date: 13 Jan 2002 21:00:40
Message: <chrishuff-A00727.21012913012002@netplex.aussie.org>
In article <3c421706@news.povray.org>, "25ct" <25c### [at] lineonenet> wrote:
The "difference" operation "cuts out" one object from another, leaving a
closed surface behind as though it were cutting a solid block of
material (though the cut surface has the texture of the cutting object).
The "clipped_by" feature is an object attribute that removes parts of
the surface outside a clipping shape, leaving gaps in the surface.
Date: 13 Jan 2002 21:59:52
Message: <3c4249a8@news.povray.org>
      Thanks for that, I understand it now.
           ~Steve~
Date: 14 Jan 2002 10:53:55
Message: <3c42ff12@news.povray.org>
Christopher James Huff <chr### [at] maccom> wrote:
: The "difference" operation "cuts out" one object from another, leaving a
: closed surface behind as though it were cutting a solid block of
: material (though the cut surface has the texture of the cutting object).
: The "clipped_by" feature is an object attribute that removes parts of
: the surface outside a clipping shape, leaving gaps in the surface.
  Note that in some cases clipping might be faster than differencing.
If the differenced surface is not seen, it's better to use clipping.
