POV-Ray : Newsgroups : povray.general : quick patch question Server Time
5 Mar 2026 10:05:00 EST (-0500)
  quick patch question (Message 1 to 5 of 5)
Subject: quick patch question
Date: 28 Dec 2001 12:53:58
Message: <3c2cb1b6$1@news.povray.org>
Given four patches with the following control points, must the * points all
be coplanar?
0 0 0 0 0 0 0
0 0 0 0 0 0 0
0 0 * * * 0 0
0 0 * * * 0 0
0 0 * * * 0 0
0 0 0 0 0 0 0
0 0 0 0 0 0 0
Thank you,
Subject: Re: quick patch question
Date: 28 Dec 2001 13:00:29
Message: <3c2cb33d@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message
news:3c2cb1b6$1@news.povray.org...
all
> be coplanar?
    Um... Lithuania? 1642? Hydrogen? The War of Northern Aggression? 32?
Preposition? Ulna? No?
Date: 28 Dec 2001 14:57:58
Message: <3c2ccec6@news.povray.org>
Shay <sah### [at] simcopartscom> wrote:
: Given four patches with the following control points, must the * points all
: be coplanar?
: 0 0 6 6 6 0 0
: 0 0 5 5 5 0 0
: 1 2 * * * 3 4
: 1 2 * * * 3 4
: 1 2 * * * 3 4
: 0 0 7 7 7 0 0
: 0 0 8 8 8 0 0
  It depends on what you want to achieve. If you want them to form a completely
contiguous smooth surface, then those points should be co-planar (ie. lay
on the same plane) and the points which I marked with numbers should be
co-linear (ie. lay in the same line, ie. points with the same number should
lay in the same line).
Date: 28 Dec 2001 17:10:05
Message: <3c2cedbd@news.povray.org>
> them to form a completely contiguous smooth surface,
> then those points should be co-planar (ie. lay on the
> same plane)
No, I think it's enough that the three rows are co-linear and the three
columns are co-linear. All nine points don't have to be co-planar.
> the same number should lay in the same line).
True.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Nov 5)
Date: 28 Dec 2001 18:12:51
Message: <3c2cfc73@news.povray.org>
Rune <run### [at] mobilixnetdk> wrote:
: No, I think it's enough that the three rows are co-linear and the three
: columns are co-linear. All nine points don't have to be co-planar.
  Yes, you are right.
