POV-Ray : Newsgroups : povray.general : normal/slope question Server Time
13 Jan 2026 22:41:31 EST (-0500)
  normal/slope question (Message 1 to 9 of 9)
Subject: normal/slope question
Date: 19 Dec 2001 07:50:30
Message: <3c208d16@news.povray.org>
Hi, I want to get the directions of the normals of a surface to use them in
a pigment. I thought that I could use a combination of 3 slope patterns to
do that
but I don't know how to get the direction when I have 3 vectors and the
degrees in that it stands to them.
Subject: Re: normal/slope question
Date: 19 Dec 2001 09:11:20
Message: <jq712ugbg4104l5q1nus1g5gnri28cnt0h@4ax.com>
On Wed, 19 Dec 2001 13:46:11 +0100, "Simon Adameit" <gom### [at] gmxde> wrote:
>do that
I'm not sure I understand slope pattern well but perhaps you expect something
like this ?
#version 3.5;
global_settings{
  assumed_gamma 1.0
  noise_generator 2
background{color rgb 1}
camera{
  orthographic
  location -2*z
  direction z
  up y
  sky y
  look_at z
light_source{
  <-30,30,-30>
  color rgb 1
sphere{
   0  .5
   normal{granite}
   pigment{
     average
     pigment_map{
       [3 slope x color_map{[0 rgb 0][1 red 3]}]
       [3 slope y color_map{[0 rgb 0][1 green 3]}]
       [3 slope z color_map{[0 rgb 0][1 blue 3]}]
// ABX
Date: 19 Dec 2001 09:18:11
Message: <3c20a1a3@news.povray.org>
something
> like this ?
>    pigment{
>      average
>      pigment_map{
>        [3 slope x color_map{[0 rgb 0][1 red 1]}]
>        [3 slope y color_map{[0 rgb 0][1 green 1]}]
>        [3 slope z color_map{[0 rgb 0][1 blue 1]}]
> ABX
I have something like this but my question is how I can get the direction of
the normal from the colors I get from this pigment.
Date: 19 Dec 2001 09:29:50
Message: <3c20a45e@news.povray.org>
"Simon Adameit" <gom### [at] gmxde> wrote in message
news:3c20a1a3@news.povray.org...
of
Ah, well then you want to use trace().  It can get you the normal vector
which could then be used as color vector.  The example in the documentation
should be enough to go by.
text{ttf"timrom""bob h"0,0pigment{rgb 7}translate 7*z}
Date: 19 Dec 2001 10:00:50
Message: <3c20aba2@news.povray.org>
documentation
I want to make a pigment that uses the direction of the normal at each point
of the surface, this is not possible with trace.
Date: 19 Dec 2001 10:15:49
Message: <dkb12uk7ta6f8lkr3b56on9b7qcbnf3po8@4ax.com>
On Wed, 19 Dec 2001 16:00:12 +0100, "Simon Adameit" <gom### [at] gmxde> wrote:
If slope pattern is proportional to normal vie on Direction parameter then I
think
pigment{
     average
     pigment_map{
       [3 slope x color_map{[0 red   -3][1 red   3]}]
       [3 slope y color_map{[0 green -3][1 green 3]}]
       [3 slope z color_map{[0 blue  -3][1 blue  3]}]
returns direction of the normal. But if slope pattern is proportional to the
angle then I'm wrong.
ABX
Date: 19 Dec 2001 10:16:53
Message: <3c20af65$1@news.povray.org>
point
Using your 3-slopes trick, you should be able to define a function,
and then use it as a pattern.  A pattern of a function of three patterns.
Fabien.
Date: 19 Dec 2001 10:48:47
Message: <3c20b6df@news.povray.org>
That's what I wanted to do :-)
Date: 19 Dec 2001 10:48:48
Message: <3c20b6e0$1@news.povray.org>
the
From reading the Docs I thought it is but I'm not sure.
