POV-Ray : Newsgroups : povray.general : how to render pov1.0 scenes with pov 3.1g Server Time
19 Jun 2026 15:09:37 EDT (-0400)
  how to render pov1.0 scenes with pov 3.1g (Message 1 to 10 of 14)
Subject: how to render pov1.0 scenes with pov 3.1g
Date: 8 Dec 2001 10:55:10
Message: <3c1237de$1@news.povray.org>
Hello,
i'm using Lissajou to create files for povray. The output is still 1.0.
How can i render this files with pov 3.1g?
You can have a look at this file at
http://www.linuxclass.de/povray/demo/bas02.pov
it's about 300k.
Thanks in advance.
regards
Volker
Volker Duetsch
eMail: vol### [at] gmxde - inf### [at] linuxclassde
Subject: Re: how to render pov1.0 scenes with pov 3.1g
Date: 8 Dec 2001 10:57:50
Message: <3c12387e$1@news.povray.org>
Sorry the URL is
http://www.linuxclass.de/povray/demo/bas02.pov.txt
Volker Duetsch
Date: 8 Dec 2001 11:32:04
Message: <3c124084@news.povray.org>
Volker Duetsch <Vol### [at] gmxde> wrote:
: i'm using Lissajou to create files for povray. The output is still 1.0.
: How can i render this files with pov 3.1g?
  Try putting
#version 1.0
at the beginning of the pov-file to see if you have any luck.
Date: 8 Dec 2001 12:07:03
Message: <3c1248b7$1@news.povray.org>
with version 1.0 I just can render it, but only if I outqoute
//#include "textures.inc". Any chance to use textures.inc with
version 1.0.
Thanks for the hint ;)
Volker Duetsch
Date: 8 Dec 2001 13:12:06
Message: <3C1257F6.356616F8@gmx.de>
Volker Duetsch wrote:
> Hi,
> version 1.0.
There is nothing from 'textures.inc' in your scene file, but if you need
it somewhere else you can try to use the version coming with Povray 1.0.
BTW, converting syntax to 3.1 is not that difficult either, just add
commas in the vectors, replace 'composite' with 'union' and change the
texture syntax.
Date: 8 Dec 2001 13:22:03
Message: <3C125AE2.D0234035@pacbell.net>
> > Hi,
> > version 1.0.
> texture syntax.
On a 300k file it's not that easy.
Ken Tyler
Date: 8 Dec 2001 13:56:49
Message: <59lJQIAMHmE8EwtV@econym.demon.co.uk>
Wasn't it Volker Duetsch who wrote:
>Hi,
>version 1.0.
It's perfectly OK to switch #version numbers during a scene. Try putting
the "#version 1.0;" after you #include any files that come with v3.1.
#version 3.1;
#version 1.0;
Textures.inc tries to switch #version numbers for itself, but it doesn't
quite work. It uses a feature that's not supported under the #version
1.0 syntax before it has switched to #version 3.1.
Mike Williams
Gentleman of Leisure
Date: 8 Dec 2001 14:16:59
Message: <3C12672B.4126E011@gmx.de>
Oh, come on, even the commas are only slightly more advanced 'search &
replace'.
Date: 8 Dec 2001 18:30:44
Message: <MPG.167cc0ebaac170289896ca@news.povray.org>
In article <3c1237de$1@news.povray.org>, Vol### [at] gmxde says...
Just create everything in Povray. It really doesn't make much sense to
use an external program for this kind of things.
I'll post a script for generating lissajou shapes to
povray.text.scene-files ASAP
Lutz-Peter
Date: 9 Dec 2001 07:48:43
Message: <3c135dab@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
: On a 300k file it's not that easy.
  Perhaps in Windows... ;)
