POV-Ray : Newsgroups : povray.general : Undefine macro? Server Time
23 Apr 2026 18:24:47 EDT (-0400)
  Undefine macro? (Message 1 to 10 of 21)
Subject: Undefine macro?
Date: 6 Dec 2001 09:26:06
Message: <3c0f7ffe@news.povray.org>
I really need to be able to undefine macros, but it doesn't seem to be
possible...?
I find it strange, as it's possible to overwrite a macro, just like
variables, and to check if a macro is defined using #ifdef, just like
variables, but to undefine it isn't possible for some reason (or is it?).
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Nov 5)
Subject: Re: Undefine macro?
Date: 6 Dec 2001 09:44:18
Message: <3c0f8442$1@news.povray.org>
Why do you need to undefine it?
Not trying to be confrontational, it may help to find a solution.
-tgq
"Rune" <run### [at] mobilixnetdk> wrote in message
news:3c0f7ffe@news.povray.org...
> possible...?
> Rune
> 3D images and anims, include files, tutorials and more:
Date: 6 Dec 2001 13:04:20
Message: <3c0fb324@news.povray.org>
In my particle system many settings are specified with macros rather than
with variables. The particle system can be called more than once in the same
scene, and sometimes you want some settings to be specified the first time
the system is called, but not the second time.
Rune
Date: 6 Dec 2001 22:08:10
Message: <3c10329a@news.povray.org>
Have you tried #undef ???
If that doesn't work, perhaps you could redefine it after it is called
based on a flag set within the macro?
N Shomber
Date: 6 Dec 2001 23:36:15
Message: <slrna10hq6.kpj.ron.parker@fwi.com>
Can you just redefine it to do nothing?
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 7 Dec 2001 03:33:56
Message: <3c107ef4@news.povray.org>
Rune wrote in message <3c0f7ffe@news.povray.org>...
>possible...?
You should be able to "undefine" a macro by redefining it as something like:
#macro mymacro(a,b,c)
  /* A macro that does nothing */
Mark
Date: 7 Dec 2001 04:34:48
Message: <3C108A14.18681430@namtar.qub.ac.uk>
From this I assume Rune means that his system checks whether or not the
macro is defined (using #ifdef), else it assigns a default value;
redefining the macro to do nothing wouldn't be any use here.
signature{
  "Grey Knight"
  contact{ email "gre### [at] yahoocom" }
  site_of_week{ url "http://www.esite-host.com/~rocketmg/" }
Date: 7 Dec 2001 07:33:41
Message: <3c10b725$1@news.povray.org>
This may not be what rune is looking for, if  I understand correctly.  If
you do this, you may end up getting an error when you try to use the macro.
If you could undefine it, then you could check if it is defined, and only
run it if it was.
Or perhaps I'm just putting words in your mouth.
-tgq
"Mark Wagner" <mar### [at] gtenet> wrote in message
news:3c107ef4@news.povray.org...
> >possible...?
like:
> #end
> Mark
Date: 7 Dec 2001 07:37:49
Message: <3c10b81d$1@news.povray.org>
"Trevor Quayle" <Tin### [at] hotmailcom> wrote in message
news:3c10b725$1@news.povray.org...
macro.
> run it if it was.
> -tgq
Just thinking, if this is the case perhaps you could do something like:
#macro MyMacro(a,b,c)
    "XXX"
then check using:
#if(MyMacro(a,b,c) != "XXX")
-tgq
Date: 7 Dec 2001 07:44:41
Message: <fvd11uobje6lksrem9uvv32761em5l6pf8@4ax.com>
> possible...?
Could it be good workaround for you ?
#version 3.5;
#include "strings.inc"
#macro Define_Macro(Name)
  Parse_String(concat("#declare Macro_",Name,"_Defined=yes"))
#macro Undefine_Macro(Name)
  Parse_String(concat("#undef Macro_",Name,"_Defined"))
#macro Is_Macro_Defined(Name)
  Parse_String(concat("(defined(Macro_",Name,"_Defined)"))
I have not tested this becouse of "Instances" problem of current beta, sorry.
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
