POV-Ray : Newsgroups : povray.general : Creating Water Height Field Server Time
24 Mar 2026 10:51:20 EDT (-0400)
  Creating Water Height Field (Message 1 to 3 of 3)
Subject: Creating Water Height Field
Date: 27 Nov 2001 13:42:16
Message: <3c03de88@news.povray.org>
Hi
Im after a way to create some nice realistic wavey water using a height
field. I have experimented with bozo patterns etc to create the black and
white picture for use within a height field with limited results. Any hits
and tips would be appreciated.
Davey B
Subject: Re: Creating Water Height Field
Date: 27 Nov 2001 14:16:54
Message: <3C03E6BE.1020103@ignorancia.org>
 > height field. I have experimented with bozo patterns etc to create
 > the black and white picture for use within a height field with
 > limited results. Any hits and tips would be appreciated.
  Do not use only one pattern. Try using a pigment_map of several
patterns (2 or 3) for the b&w image, with different scaling and
turbulence parameters. Also, if using the new 3.5 beta, try the function
image pattern, very handy to avoid external b&w files.
Jaime Vives Piqueres
http://www.ignorancia.org/
Date: 27 Nov 2001 17:17:29
Message: <3c0410f9@news.povray.org>
Davey B wrote:
> Hi
If you're not afraid of a modest parse time you could check p.b.s-f.
Hormann posted a function that is quite easily converted into a hf with
height_field { function n,n { } }. there are some recently posted anims and
a pic
in the binaries groups.
-Jide
