POV-Ray : Newsgroups : povray.general : putting textures on a difference object Server Time
16 Jul 2026 20:04:50 EDT (-0400)
  putting textures on a difference object (Message 1 to 5 of 5)
Subject: putting textures on a difference object
Date: 25 Nov 2001 19:10:31
Message: <3c018877$1@news.povray.org>
so I'm trying to put a texture on a csg (difference) object. The problem is that that
the texture doesn't come out correctly.
Here's what I'm talking about:
#declare White_Brick=texture{
    pigment{
      brick pigment{Gray90}, pigment{White}
      brick_size <3, 1, 2>
      mortar .5
      scale 1
light_source{
  <0,500,-500>, White
      difference{
        box{
          <-15, 0, -15>, <15, 43, 15>
        box{
          <-100, -100, 00>, <100, 100, -100>
          translate z*-15
          rotate x*10
        box{
          <0, -100, 100>, <100, 100, -100>
          translate x*15
          rotate z*10
        translate <47, 0, -47>
        rotate y*counter*90
What you should see is that on the side where the difference isn't applied, the brick
pattern works
However, on the side where the difference was applied, there're gray bars where bricks
should be.
Any idea how to solve this?
-John
Subject: Re: putting textures on a difference object
Date: 26 Nov 2001 04:38:59
Message: <3C020DCA.1010705@ignorancia.org>
brick pattern works
bricks should be.
I have not rendered your code, but seems to me this is the mortar of the
bricks, wich casually coincides with the cut. Try to move the texture
slighty... hope this helps.
Jaime Vives Piqueres
http://www.ignorancia.org/
Date: 2 Dec 2001 17:50:08
Message: <3c0ab020$1@news.povray.org>
Is there anyway to apply the texture to each side individually?
ie apply it normally on the sides w/o the difference, and rotate the texture
on the side where the texture is applied?
Thanks!
Date: 2 Dec 2001 23:39:17
Message: <3c0b01f5@news.povray.org>
<the### [at] yahoocom> wrote in message
news:3c0ab020$1@news.povray.org...
texture
I rendered it and couldn't see anything wrong, all sides are the same brick
pattern.  Albeit it will look a little different depending on where the
camera is and the size of the image.
If you try my changed script and use the AA settings too you will see:
// +a0.1 +r5  // try this and also +a +r3 the default AA
    pigment{
      brick pigment{rgb .9}, pigment{rgb 1}
      mortar .5
      scale 1
#declare C=4;
#while (C>0)
      difference{
        box{
        box{
          <-100, -100, 0>, <100, 100, -100>
          translate z*-15
          rotate x*10
        box{
          translate x*15
          rotate z*10
 texture {White_Brick}
        rotate y*C*90
#declare C=C-1;
light_source{
  <0,50,150>, 1
camera {location <0,25,100> look_at 0}
Date: 3 Dec 2001 03:56:11
Message: <3C0B3E45.5050801@ignorancia.org>
  I usually do this by having different objects for each side. It's a
bit more of work to decompose your whole difference into pieces, but it
is worth the effort.
