POV-Ray : Newsgroups : povray.general : Trace()? Server Time
23 Apr 2026 20:02:23 EDT (-0400)
  Trace()? (Message 1 to 10 of 31)
Subject: Trace()?
Date: 12 Nov 2001 19:08:47
Message: <3bf0648f$1@news.povray.org>
Could anyone explain to me exactly how one uses the trace() function to
detect object collisions? The docs say that 'trace() can be used to detect
the exact point a ray intersects a surface' and then gives a perfectly
incomprehensible (to me at least) example.
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare T=texture{pigment{crackle
scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
Subject: Re: Trace()?
Date: 13 Nov 2001 01:52:02
Message: <3BF0C313.DE3D24B8@gmx.de>
You will find une in the insert menu:
// trace function tests for intersection with a specified object
#declare Obj = sphere { 0, 1 }
#declare Norm = <0, 0, 0>;
#declare Start = <0.5, 0.5, 1>;
#declare Pos = trace (
                  Obj,             // object to test
                  Start,           // starting point
                  -z,              // direction
                  Norm );          // normal
// if intersection is found, normal differs from 0
#if (Norm.x != 0 | Norm.y != 0 | Norm.z != 0)
Date: 13 Nov 2001 03:23:48
Message: <3bf0d894@news.povray.org>
Mahalis <don### [at] fakeycom> wrote:
: Could anyone explain to me exactly how one uses the trace() function to
: detect object collisions?
  If you mean that you want to detect if an object collided with another
object, regardless of shape, then that's one of the most difficult things
to do. Tracing can help a bit, but that's only perhaps 0.1% of everything you
need for that.
Date: 13 Nov 2001 03:48:17
Message: <ucn1vt8lo1a1ebi08ehvjgv93g1u6r4dvf@4ax.com>
You are talking about 3.5, right? Check trace.pov and trace2.pov in
POV3.5/scenes/language/ directory.
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 13 Nov 2001 18:11:55
Message: <3bf1a8bb$1@news.povray.org>
I didn't exactly mean 'colliding' as in 'running into'; I meant 'colliding'
as in 'intersecting'.
//Mahalis
news:3bf0d894@news.povray.org...
you
> need for that.
Date: 13 Nov 2001 23:07:06
Message: <3bf1edea$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3bf0d894@news.povray.org...
> need for that.
This reminds me, I just thought of something for my 4.0 wishlist.  A function
like inside that works for objects instead of vectors, as in:
    #declare A = sphere { 0, 1 }
    #declare B = sphere { 0.5*x,1 }
    #if (intersect(A,B)) #debug "A intersects B\n" #end
That would make collision detection *much* easier.
Hmmm... is this always guaranteed to work?
    #include "stdinc.inc"
    #include "shapes.inc"
    #declare B = box { 2, 3 }
    #declare Min = x*0;
    #declare Max = x*0;
    Extents(intersection { object { A } object { B } }, Min, Max)
    #if (!VEq(Max,<10000000000,10000000000,10000000000>)) #debug "A intersects
B\n"
    #else #debug "A does not intersect B\n"
    #debug concat(VStr(Min), "  ", VStr(Max))
I would suppose it depends on what POV-Ray assigns as the Min/Max for a
degenerate bounding box.  And if the DBB is always possible to detect.
It appears to work with primatives and small CSGs... but I could be wrong.
Haven't tested it much.
Any thoughts?
Michael
#macro M(D)#local J=strlen(D);#local _=""#while(J>0)#local _=concat(_,substr(D
,J,1))#local J=J-1;#end _#end sphere{z*9,5pigment{rgb x}}#macro N(D,J)text{ttf
"timrom.ttf"M(D)1,0 translate-J}#end#macro O(E,K)#local _=N(E,K)light_source{-
z*9rgb 1projected_through{_}}#end O("leahciM"<1.6,-.3.9>)O("nosnhoJ"<1.6.9.9>)
Date: 14 Nov 2001 01:33:29
Message: <3bf21039@news.povray.org>
: I didn't exactly mean 'colliding' as in 'running into'; I meant 'colliding'
: as in 'intersecting'.
  The problem is still exactly the same and exactly as difficult.
Date: 14 Nov 2001 01:36:41
Message: <3bf210f9@news.povray.org>
Redbeard <red### [at] wvadelphianet> wrote:
: This reminds me, I just thought of something for my 4.0 wishlist.  A function
: like inside that works for objects instead of vectors, as in:
:     #declare A = sphere { 0, 1 }
:     #declare B = sphere { 0.5*x,1 }
:     #if (intersect(A,B)) #debug "A intersects B\n" #end
  As I said, that's extremely difficult to implement for any given object.
Of course it's trivial for spheres, but if you want to support any object,
you are approximating the impossible.
:     Extents(intersection { object { A } object { B } }, Min, Max)
  Note that even if the bounding boxes of the objects intersect, that doesn't
mean that the objects themselves do.
: It appears to work with primatives
  Again that word...
Date: 14 Nov 2001 01:47:48
Message: <3BF213CD.3CBDBBC7@pacbell.net>
>   Again that word...
I'll teach them to stop using "that" word if you stop using "drastical" :)
Ken Tyler
Date: 14 Nov 2001 02:00:58
Message: <3bf216a9@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
: I'll teach them to stop using "that" word if you stop using "drastical" :)
  Some english words confuse me a lot.
  The word "drastically" exists. By logic, it would come from the word
"drastical" (drastical + ly = drastically).
  But no, it comes from the word "drastic".
  By reverse logic, it would mean that drastic + ly = drasticly.
  But no, it's drastic + ly = drasticALly.
  It makes no sense.
