POV-Ray : Newsgroups : povray.general : Fade to white? Server Time
14 Jan 2026 03:36:07 EST (-0500)
  Fade to white? (Message 1 to 7 of 7)
Subject: Fade to white?
Date: 4 Nov 2001 21:47:08
Message: <3be5fdac@news.povray.org>
For changing scenes in an animation, I want to "fade to white" instead
of fade to black.  Going to black is easy: turn off all the lights.
But when I tried this with a fog, even with a distance of "0", I still
saw alot of detail in a close-up of a character's face.   Any other
tips?
Subject: Re: Fade to white?
Date: 4 Nov 2001 22:40:15
Message: <3BE609DE.6020806@niftythings.org>
> tips?
I imagine you could use a white box or plane in front of the camera with
no_shadow, ambient 1, and alter its transparency.
-Ben
Date: 5 Nov 2001 04:42:44
Message: <3be65f14$1@news.povray.org>
"Ben Udall" <ben### [at] niftythingsorg> wrote in message
news:3BE### [at] niftythingsorg...
Or a tiny sphere around the camera.  Wonder what happens if the global
ambient_light is changed from 1 to 100 though?  Might make for a different
and interesting effect.
Check it and doesn't go right with reflection, sky_sphere or background
color.
Bob H.
Date: 5 Nov 2001 19:29:38
Message: <3be72ef2$1@news.povray.org>
No, ambient light won't work, no matter ho light you make it, any black will
remain black with even the highest ambient
Date: 6 Nov 2001 08:44:03
Message: <3BE7E8B9.9E037135@aol.com>
> tips?
try distance = 1e-6 instead of 0.
Date: 6 Nov 2001 10:36:07
Message: <3be80367$1@news.povray.org>
It depends how you want the fade to work. If you use fog, objects further
away will fade to white before closer ones.  For a uniform fade try, as
others stated, a white, no_shadow sphere around the camera and vary the
transparency.
-tgq
"Greg M. Johnson" <"gregj;-)56590\""@aol.c;-)om> wrote in message
news:3be5fdac@news.povray.org...
> tips?
Date: 6 Nov 2001 13:10:46
Message: <3be827a6$1@news.povray.org>
"Trevor Quayle" <Tin### [at] hotmailcom> wrote in message
news:3be80367$1@news.povray.org...
Oops, sorry, I spoke a bit too quick on that one, this is only the case if
you vary the distance or use a selected range of distance, This is not
really the case if you use a fixed short distance and vary the transparency.
> transparency.
> -tgq
