POV-Ray : Newsgroups : povray.general : Specular Server Time
24 Mar 2026 14:22:53 EDT (-0400)
  Specular (Message 1 to 10 of 11)
Subject: Specular
Date: 4 Nov 2001 07:22:38
Message: <3be5330e@news.povray.org>
Hi All
Don't really know where to put this...
I have been attempting to create realistic figures using image maps and
amongst the many problems I have encountered is adding specular to semi
transparent meshes.
What I need to do is add specular highlights to the opaque parts of the mesh
only.
Is this a reson for specular maps?
Any suggestions?
Mick
Subject: Re: Specular
Date: 4 Nov 2001 07:27:47
Message: <3be53443@news.povray.org>
Instead of using a color_map to define transparent and non-transparent areas
use a texture_map. Then for the transparent areas don't use specular in the
finish block.
Finish_maps would help a lot here.
Jonathan.
"Mick Hazelgrove" <mic### [at] mhazelgrovefsnetcouk> ha scritto nel messaggio
news:3be5330e@news.povray.org...
> Hi All
> transparent meshes.
mesh
> only.
> Any suggestions?
> Mick
Date: 4 Nov 2001 07:38:26
Message: <3be536c2@news.povray.org>
"JRG" <jrg### [at] hotmailcom> wrote in message
news:3be53443@news.povray.org...
areas
> use a texture_map.
I'm using an image map with the transparent areas defined by the alpha
channal attached to the image map - so I can't really do this.
Mick
Date: 4 Nov 2001 07:59:45
Message: <3be53bc1$1@news.povray.org>
Oops. Sorry.
Maybe you may try to use a greyscale version of your image_map as pattern
for a texture_map (and use your normal image_map inside every textures).
Jonathan.
news:3be536c2@news.povray.org...
> areas
> > use a texture_map.
> Mick
Date: 4 Nov 2001 09:21:25
Message: <3be54ee5@news.povray.org>
Extract the alpha channel to another file and use it as an image_pattern? Or
did I miss the boat here?
Date: 4 Nov 2001 10:35:53
Message: <3be56059@news.povray.org>
I second JRG's option. I ran recently into a similar problem and using
image_pattern was the way to go. An added benefit was the possibility of
using JPEG instead of extremely large TGA or PNG.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
news: 3be536c2@news.povray.org...
> areas
> > use a texture_map.
> Mick
Date: 4 Nov 2001 11:18:55
Message: <3be56a6f$1@news.povray.org>
"Mick Hazelgrove" <mic### [at] mhazelgrovefsnetcouk> wrote in message
> areas
> > use a texture_map.
> Mick
JRG and Tony have it right. Finish maps would be useful here but the only two
ways I've discovered to vary the finish across a surface with bitmaps are using
either a material_map or 3.5's image_pattern. Image_pattern is the friendlier of
the two, from both usability and system memory consumption, standpoints.
Just declare your pigment{} (and possibly normal{}) using your image_map and
then declare two textures that use these with different finish statements.
Finally create a grayscale image from your original image_map and use the map
part of the image_pattern statement to control the blend between the two
textures.
For perspective, a material_map would employ basically the same technique only
you would have to pre-declare up to 255 textures differing only in finish
(yech!).
I can't say at the moment whether the alpha will work better in the
image_pattern or is best left in the original image_map, since I haven't tried
that yet.
Good Luck!
Batronyx ^"^
Date: 4 Nov 2001 11:49:03
Message: <3be5717f@news.povray.org>
I think I see what you mean, I'll have to play - trouble is I'm short of
time at the moment - oh well.
Mick
Date: 4 Nov 2001 13:04:01
Message: <3be58311@news.povray.org>
Hi Gilles
I've just read up image_pattern(three times) and I reckon I understand what
I've got to do now. Just have to find time to play!
Mick
Date: 4 Nov 2001 14:34:17
Message: <3be59839@news.povray.org>
Hi Mick,
look to a recent thread of Alan Holding named "Uh oh.." in p.b.i.
Gilles made code suggestions regarding image_pattern for faking
specularmaps.
Norbert
"Mick Hazelgrove" <mic### [at] mhazelgrovefsnetcouk> schrieb im Newsbeitrag
news:3be58311@news.povray.org...
> Hi Gilles
what
> Mick
