POV-Ray : Newsgroups : povray.general : Rounding a Cylinder Server Time
25 May 2026 09:36:25 EDT (-0400)
  Rounding a Cylinder (Message 1 to 4 of 4)
Subject: Rounding a Cylinder
Date: 6 Oct 2001 08:28:34
Message: <3bbef8f2@news.povray.org>
Okay all, just a little bit of help.. I've been trying to come
up with this formula for a while loop to create a round
set of small cylinders.
I start out with one small cylinder at:
x = 0, y=0, z=-4.5
I know that 1/4 of the way through it should be at
x=4.5, y=0, z=0
1/2 the way through:
x=0, y=0, z=4.5
and 3/4 of the way:
x=-4.5, y=0, z=0
and then back again to:
x=0, y=0, z=-4.5 (However I don't want to go this far
Now I've been trying something like:
(where Offset is the spacing between Cylinders)
#declare X = X + (Offset + .25); (.25 is the circ of the cylinder)
#declare Z = Z + (Offset)
But it doesn't go around, it just makes a bee-ling down the Z axis..
Any help would be lovely.'
Thanks
Subject: Re: Rounding a Cylinder
Date: 6 Oct 2001 09:04:13
Message: <3BBF022B.282471DC@gmx.de>
How about:
#declare Angle=0;
#while (Angle < 2*pi)
  #declare Point=<cos(Angle), sin(Angle), 0>;
  #declare Angle=Angle+(2*pi/50);
  #declare Point2=<cos(Angle), sin(Angle), 0>;
  cylinder { Point, Point2, 0.05 }
Note that you can also use 'rotate' instead of trigonometry.
Date: 6 Oct 2001 09:13:09
Message: <GibqFPAUJwv7EwOO@econym.demon.co.uk>
>x = 0, y=0, z=-4.5
>x=4.5, y=0, z=0
>x=0, y=0, z=4.5
>and 3/4 of the way:
>x=-4.5, y=0, z=0
I'd do it like this: Move each cylinder to -4.5*z and then rotate them
around the origin by different amounts.
#declare Height = 1; // Length of each cylinder
#declare Radius = 0.2; // Radius of each cylinder
#declare Separation = 10; // degrees
#declare A=0;
#while (A<360)
  cylinder {<0,0,0>,<0,Height,0>,Radius
     pigment {rgb 1}
     translate -4.5*z
     rotate y*A
  #declare A=A+Separation;
Mike Williams
Gentleman of Leisure
Date: 6 Oct 2001 09:49:49
Message: <3bbf0bfd@news.povray.org>
DuH!..
Is see now.. I wasn't even think cos, and sin..
And I didn't EVER think of rotate, rotate might be nicer on the loop.
Thanks all
> How about:
> #declare Angle=0;
> #end
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
