POV-Ray : Newsgroups : povray.general : Should this take 5 mins to render? Server Time
30 Dec 2025 18:13:21 EST (-0500)
  Should this take 5 mins to render? (Message 1 to 4 of 4)
Subject: Should this take 5 mins to render?
Date: 2 Oct 2001 19:16:46
Message: <3bba4ade@news.povray.org>
I am rendering one instance of this object, nothiung else and it's taking
5 mins.  But other (lathe) objects take around 1 min under teh same
lighting conditions, and same texture...
#local Scol = difference
		#local Count=0;
		#while (Count < 50)
		object
			torus {6.3,1.2}
			translate <0,0.1 * Count,0>
		#local Count=Count+1;
		box {<-10,-10,-10>,<10,10,0>}
	texture
		Cowling
  Rob Brown-Bayliss
 ---======o======---
Subject: Re: Should this take 5 mins to render?
Date: 2 Oct 2001 22:06:12
Message: <3BBA73DF.9E8759E3@pacbell.net>
>                 #local Count=0;
>                 #while (Count < 50)
You are differencing 50 torus objects from each other. Reduce that number to
2 and it will render considerably faster. Considering what you were doing
5 min. is not at all out of line.
Ken Tyler
Date: 2 Oct 2001 22:15:35
Message: <3bba74c7@news.povray.org>
In article <3BBA73DF.9E8759E3@pacbell.net>, "Ken" <tyl### [at] pacbellnet>
>> taking 5 mins.  But other (lathe) objects take around 1 min under teh
>> same lighting conditions, and same texture...
>>                 #local Count=0;
>>                 #while (Count < 50)
> number to 2 and it will render considerably faster. Considering what you
> were doing 5 min. is not at all out of line.
huh, Idiot, I ment to to a union...  Bummbr, I have since changed my
design to this:
	#local Outer = difference
		intersection
			sphere {<0, 0, 0>, 8.3}
			box {<0,-3,-1>,<10,3,5>}
		sphere {<0, 0, 0>, 6.3}
	difference
		object {Outer}
		difference
			intersection
				sphere {<0, 0, 0>, 8.2}
				box {<0,-2.9,-1.5>,<10,2.9,5>}
			sphere {<0, 0, 0>, 6.4}
  Rob Brown-Bayliss
 ---======o======---
Date: 3 Oct 2001 05:55:01
Message: <38nep9.uv1.ln@micha.riser>
> intersection
> difference
> object {Outer}
> difference
> intersection
union{
        intersection{
                sphere {<0, 0, 0>, 8.2 inverse}
        intersection{
                sphere {<0, 0, 0>, 6.3 inverse}
        intersection{
                box {<0,2.9,-1.5>,<10,3,5>}
        intersection{
                box {<0,-2.9,-1.5>,<10,-3,5>}
works a little bit faster when you have automatic bounding turned on.
- Micha
