POV-Ray : Newsgroups : povray.general : How do you position reg. objs+blobs? Server Time
30 Dec 2025 20:37:16 EST (-0500)
  How do you position reg. objs+blobs? (Message 1 to 10 of 11)
Subject: How do you position reg. objs+blobs?
Date: 19 Sep 2001 17:15:37
Message: <3ba90af9$1@news.povray.org>
How can you tell what the radius of a blob will be at any particular point
(is there some sort of formula)? Whenever I try to position a regular sphere
touching a blob, it doesn't look anything like I want it to.
Subject: Re: How do you position reg. objs+blobs?
Date: 19 Sep 2001 17:35:05
Message: <3ba90f89$1@news.povray.org>
"Mahalis" <don### [at] fakeycom> wrote in message
news:3ba90af9$1@news.povray.org...
sphere
    I am sure there is a formula for more complex shapes, but the general
idea is simple. If your radius is 1 and the threshold is 0.5, the surface is
0.5 units from the origin.
Date: 20 Sep 2001 07:52:14
Message: <3ba9d86e@news.povray.org>
> but the general idea is simple. If your radius is 1 and
> the threshold is 0.5, the surface is 0.5 units from the
> origin.
That's not true. In this case it's pretty close to 0.5, but if you try to
change the threshold to 0.1 or 0.9 you'll see great differences. BTW, this
all assumes that the strength is 1; I'm sure that's what you meant too.
I can't remember the real formula right now, but it should be possible to
derive it from my easyblob macro, which you can find here:
http://rsj.mobilixnet.dk/3d/blobs/blobs.html
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated June 26)
Date: 20 Sep 2001 09:31:38
Message: <3BA9EFD8.39019539@aol.com>
The formula is radius*(threshold -1)*strength. In other words, if your
threshold is .4, your radius is 1, and your strength is 1, the apparent size
of your blob component will be (1-.4)*1*1 or .6*1*1, or .6.
Date: 20 Sep 2001 10:13:20
Message: <3BA9F99D.8F2C84A8@aol.com>
That should be, of course (1-threshold)  :{
Date: 20 Sep 2001 11:58:44
Message: <3BAA13D4.54CA4C7C@reading.ac.uk>
The R*S*(1-T) formula falls down for strength != 1. It can give an
observed radius larger than the given radius which never happens.
Actually, the density of a single spherical blob is given in ss6.5.1.1
of the v3.5 docs. Since the observed radius is where the density equals
the threshold, actual radius is given as
 A = R*sqrt(1-sqrt(T/S))
where
R = given radius
S = component strength
T = threshold
so your example of  T = 0.4, S = 1, R = 1 gives A = ~0.606
Bet you wanted to know that, hmm? :-)
Bye for now,
	Mike Andrews.
Date: 20 Sep 2001 15:11:42
Message: <3BAA3F8B.935B0C17@aol.com>
Who knew, heh heh. Guess I never use strengths other than 1 or -1. Live and learn.
Thanks for the tip.
Date: 20 Sep 2001 16:02:45
Message: <3BAA4B81.A31EB2BE@aol.com>
Thought I'd try and salvage a bit of my integrity, anyway. The formula I gave for the
visible size of a blob component will work when the strength value <1. In other words,
if your strength is .5, you can apply the formula to get the apparent radius. Where it
breaks down is if strength >1.
Date: 21 Sep 2001 09:20:12
Message: <3BAB3E36.5972BD28@aol.com>
Jettison all math.  If you have a cool blob object, it will have dozens of
components, no?
Use the trace function.
Date: 21 Sep 2001 09:25:01
Message: <0vemqtkh61gnhgpbtmjfsq9utig5ntmct4@4ax.com>
On Wed, 19 Sep 2001 17:17:20 -0400, "Mahalis" <don### [at] fakeycom>
Use trace() :)
Peter Popov ICQ : 15002700
