POV-Ray : Newsgroups : povray.general : A little vector problem Server Time
31 Dec 2025 00:13:31 EST (-0500)
  A little vector problem (Message 1 to 4 of 4)
Subject: A little vector problem
Date: 30 Aug 2001 14:35:38
Message: <3b8e877a$1@news.povray.org>
What is the easiest (fastest) way to check in pov whether the angle between
two normalized vectors is >90 degrees? I am currently testing if
vlength(A-B)>sqrt(2)
And what is the easiest way to check if two colinear vectors point in the
same direction?
- Micha
Subject: Re: A little vector problem
Date: 30 Aug 2001 15:00:30
Message: <slrn9ot3ag.3p7.ron.parker@fwi.com>
>same direction?
The answer to both questions is vdot.  For the first question, the angle is
obtuse if the dot product is negative.  For the second, they point in the same
direction if the dot product is positive.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 30 Aug 2001 15:18:28
Message: <3b8e9184$1@news.povray.org>
1) vdot()
given normalized vectors A and B, vdot(A,B) is 1 if they are parallel/equal,
0 if perpendicular, -1 if pointing in opposite directions, and in general,
cos(angle between). So the condition you are looking for is vdot(A,B)<0.
Given general normalized or un-normalized vectors,vdot(A,B)>0 means angle
less than 90, vdot(A,B)=0 are perpendicular, and vdot(A,B)<0 means angle
more than 90.
2) vdot(vnormal(A),vnormal(B))=1 for any two parallel vectors
Chris
"Micha Riser" <mri### [at] gmxnet> wrote in message
news:3b8e877a$1@news.povray.org...
between
> same direction?
> - Micha
Date: 31 Aug 2001 12:18:00
Message: <3b8fb8b8@news.povray.org>
Thank you for your answers. I just knew that there had to be a quick and
simple solution... actually I used vdot already to calculate angles between
vectors, but I thought it would be too complicated to do this for this
problem. That is why I came away from vdot.
