POV-Ray : Newsgroups : povray.general : Number range Server Time
25 May 2026 15:55:10 EDT (-0400)
  Number range (Message 1 to 4 of 4)
Subject: Number range
Date: 21 Aug 2001 04:07:21
Message: <3b8216b9$1@news.povray.org>
HI
I apologise for this probably very simple question in advance - I have a
range of numbers from .1 to 1
and I want to compress then into the range .6 to 1, I don't want to loose
any numbers or alter the proportional relationship between them just
compress it. so that .1 becomes .6 and 1 stays 1 and all other numbers
change propotionally in betwwen, hope that's clear!
Mick
Subject: Re: Number range
Date: 21 Aug 2001 04:23:06
Message: <3B821B17.C111478@engineer.com>
0.1<n<1
a=(n-0.1)/(1-0.1)*(1-0.6)+0.6
0.6<a<1
_____________
Kari Kivisalo
Date: 21 Aug 2001 04:29:29
Message: <3b821be8@news.povray.org>
The easiest "trick" to scale numbers in this way is to first scale them to
the range 0-1 and then scale them to the desired range.
  So if you have numbers between 0.1 and 1, you first scale them to be
between 0 and 1: normalized=(number-0.1)/(1-0.1)
  Now you scale this to the range 0.6-1: normalized*(1-0.6)+0.6
  If we write that into one line, it would be:
  (number-0.1)*(1-0.6)/(1-0.1) + 0.6
and simplifying a bit:
  (number-0.1)*0.4/0.9 + 0.6
Date: 21 Aug 2001 06:32:45
Message: <3b8238cd@news.povray.org>
Thanks
I get the idea now.
Mick
