POV-Ray : Newsgroups : povray.general : Field of View Server Time
31 Mar 2026 01:56:55 EDT (-0400)
  Field of View (Message 1 to 9 of 9)
Subject: Field of View
Date: 5 Aug 2001 13:28:09
Message: <3b6d8229@news.povray.org>
OK, I know I'm being lazy here, but my maths isn't that hot...
Can anyone tell me how I would go about determining if a point will be
in view given its coordinates and the camera's parameters?  See, I'm
making Antoine's necklace, a fractal object involving a very large
number of primitives, and they take up way too much memory, but many are
off the screen.
Subject: Re: Field of View
Date: 5 Aug 2001 17:32:10
Message: <3B6DB942.CE717D93@faricy.net>
> off the screen.
I wrote a macro to find the angle between two vectors.
#macro vangle(vec1,vec2)
   #local len1 = vlength(vec1);
   #local len2 = vlength(vec2);
   #local len3 = vlength(vec2-vec1);
   acos((pow(len3,2)-pow(len1,2)-pow(len2,2))/(-2*len1*len2))
So find the angle between the vector
   object position - camera position
and the vector
   camera look_at - camera position (or just camera direction)
and check if the angle is larger than your viewing angle.  Since the
camera angle goes to the edge of the pic, not the corner, you need a
bigger angle than the actual camera angle.  I think this should do it:
   atan(sqrt((1 + pow(image_height/image_width, 2)) *
pow(tan(camera_angle), 2)))
And of course you have to add a little padding for the width of the
objects...
Of course, this tells you if the object is in a cone around the field of
view, but it can be in the cone and outside the image.  So it's not 100%
efficient, but it'll work (I think).
Date: 5 Aug 2001 20:11:24
Message: <3b6de0ac@news.povray.org>
Andrew <ast### [at] hotmailcom> wrote:
: Can anyone tell me how I would go about determining if a point will be
: in view given its coordinates and the camera's parameters?
  Just as a side note: This is not possible in a general case (or at least
very difficult to do accurately).
  Why? Because POV-Ray accepts quite complicated camera definitions. For
instance, just the fact that you can apply a "normal modifier" pattern to
the camera rays makes it practically impossible.
  Of course I know you are just talking about a regular perspective camera...
Date: 5 Aug 2001 20:16:59
Message: <3b6de1fb@news.povray.org>
Using pow() in this context is a bad idea. Simple
multiplication (e.g. len3*len3) will do the trick while
being more efficient. Not by far due to the huge
parsing overhead, but...
As to the method in general -- what you propose is
not too accurate, and the other side of the cone is not
the only cause. Viewing frustum is not a cone.
I think, the right thing would be to build a matrix of
the transform inverse to the perspective one (i.e. such
transform that turns viewing frustum into a box; preferably
oriented along some axis) and then write a macro that
will apply that transform to projected primitive's
coordinates. If result is outside of the box -- well, hope
you got it.
BTW, this somewhat resembles what POV-Ray does
internally to each emitted ray while calculating intersections.
David Fontaine <dav### [at] faricynet> wrote in message
news:3B6DB942.CE717D93@faricy.net...
> > off the screen.
> #end
> and the vector
> objects...
Date: 5 Aug 2001 20:28:29
Message: <chrishuff-5EF29D.19260005082001@netplex.aussie.org>
In article <3b6de1fb@news.povray.org>,
Actually, len3*len3 might be slower...more stuff to parse, and the time
it takes to call the C pow() function is insignificant compared to the
time it takes to parse POV code. But speed is very unlikely to be of any
concern here, readability is better, try this:
#macro Sqr(V) (V*V) #end
Sqr(Len3)
BTW, it is a good idea to always include at least one capital letter in
your macro or variable identifiers...what if some future version of POV
added len1, len2, or vangle() keywords? This code would simply fail.
Christopher James Huff - chr### [at] maccom, http://homepage.mac.com/chrishuff/
Date: 5 Aug 2001 20:37:53
Message: <3b6de6e1@news.povray.org>
"more stuff to parse" -- how is that?
Chris Huff <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
> Sqr(Len3)
> TAG: chr### [at] tagpovrayorg, http://tag.povray.org/
Date: 5 Aug 2001 21:10:15
Message: <3B6DED7D.EC8AAB9A@hotmail.com>
> #end
Hello again David
I haven't tested your macro, nor the one below,
but I think this one will do the same job:
#macro VAngle(v1,v2)
  acos(vdot(vnormalize(v1), vnormalize(v2)))
#end // macro VAngle
(But maybe you already knew that ;)
Best regards,
Tor Olav
mailto:tor### [at] hotmailcom
http://hjem.sol.no/t-o-k
http://www.crosswinds.net/~tok
Date: 6 Aug 2001 12:55:15
Message: <3b6ecbf3@news.povray.org>
> off the screen.
I'm just doing something very similiar, creating a mesh with the level
of detail depending on the camera position. I'm quite sure there are some
packages which can do the same better, but maybe it gives you an idea.
#declare CAM_POS   = <0,0,0>;
#declare CAM_TO    = <0,0,10>;
#declare CAM_DIR   = vnormalize(CAM_TO - CAM_POS);
#declare CAM_UP    = vnormalize(vcross(CAM_DIR, x));
#declare CAM_RIGHT = vcross(CAM_UP, CAM_DIR);
 location CAM_POS
 direction CAM_DIR
   up CAM_UP
   right CAM_RIGHT * 4/3
// Change for other FOV, resolution
#macro Project(P, PX, PY)
 #declare PX = P.x / P.z;
 #declare PY = P.y / P.z;
// Given any position in P, you can now get the exact position on screen
Hope this is helpful
#macro C(X,Y)cylinder{X*x<X,0,-Y/2>.1}#end#macro U(R,X,Y)intersection{torus{.9
.1}box{-1 0rotate y*R*90}translate<X,0,Y>scale 1-z*.5}#end union{U(0,0,0)U(1,0
,0)U(2,-1,-1)U(1,1,0)U(1,1.5,-3)U(1,2,0)U(3,1,0)U(2,2,0)U(0,3,0)U(3,2,.5)C(.1,
2)C(.8,1)C(.8,-1)C(1.1,1)C(1.9,-1)pigment{rgb 10}rotate x*90translate<-1,0,4>}
Date: 6 Aug 2001 17:48:35
Message: <3B6F0E97.97949E45@faricy.net>
> > #end
> Hello again David
I think I tried that too but I had some reason for changing it... maybe
not?
